Posted June 18, 200916 yr i recently got an internship and in our engineering lab where i work we have many oscopes. i was wondering how i would be able to use the oscope to set the gains on my amplifier
June 19, 200916 yr i might do this too. my dad is an electrical engineer and has an o-scopethank you also.
June 19, 200916 yr Author my pops is vp of sales for fluke so i get all the free multimeters i want =) ... i have about 20 at my house lol
June 19, 200916 yr Author quick ? about the video ... meade says that his h/u clips at 60 ... y does his h/u clip? ... also why is he tunning his amps to 59? ... i thought you were supposed to set ur gains 3/4 of the way because some music is louder than others? .... he says he can play it at 59 without it ever clipping is this true or will some music cause the amp to clip?
June 19, 200916 yr quick ? about the video ... meade says that his h/u clips at 60 ... y does his h/u clip? ... also why is he tunning his amps to 59? ... i thought you were supposed to set ur gains 3/4 of the way because some music is louder than others? .... he says he can play it at 59 without it ever clipping is this true or will some music cause the amp to clip?Head units clip just like amplifiers, because they are amplifiers as well. Why wouldn't his head unit clip? All do. We set our gains at 3/4 volume because that's about the point that most head units begin to clip. He may be right about 59 never clipping, and he may be wrong. It depends on if he set the gain at 59 with a 0 db tone. Then no, nothing could be louder than that tone and it should never clip. But if he set it with just some random song, chances are another song was recorded at a higher level and it could clip.
June 19, 200916 yr Author but how does your h/u clip if you are running off of rcas ... you are not using the amplifier's hi levels
June 19, 200916 yr but how does your h/u clip if you are running off of rcas ... you are not using the amplifier's hi levelsYou can still clip a signal..
June 19, 200916 yr Author how can i check my rcas using the oscilloscope? can i just go inside pos shielding neg?
June 19, 200916 yr Author thanks again ... i still dont see how he is hooking up the outputs tho ... is it positive inside negative shielding? how would you do this with you high level outputs
June 20, 200916 yr thanks again ... i still dont see how he is hooking up the outputs tho ... is it positive inside negative shielding? how would you do this with you high level outputsare you use a fluke with clip on leads if so which one? i believe so but i must look it up be for you quote me on it. you got to remember dc flow from plus to minus you maybe able to clip the positive lead on the speaker positive and leave the speaker ground on the speaker and just ground the shield to the frame. play some thing like 150 threw reg coaxial and lower then 100 threw sub amps. play sine sweeps and square waves threw system wile testing. what your looking for is the top part of the sine wave to be clipped off or flat. on the "o" scope
June 20, 200916 yr you may need a times ten probe to get to register on the screen it's a resistance value that will multiply the voltage out put times 10 so you can see it on the screen. it should just be a shielded probe to were you just connect the one lead to the dc voltage source if there is a "y" on one lead coming off the probe connect the one positive strait to the positive of the speaker of the amp out put. or in between the speaker and the amp out put. plus and minus so it still is connected to the speaker but threw the meter. i have seen them do this in many ways so if there is a model number i may be able to read the meter manual and fill you in. the times ten probe may be some think like a ten mega ohm resistor or similar depending on which your o scope uses. any ways if you give me a model number i mite be able to help more.... all i got resistor color codes if you need me to tell you them what the resistor should be....
June 20, 200916 yr but how does your h/u clip if you are running off of rcas ... you are not using the amplifier's hi levelsA signal is a signal. It's just that the power is lower on RCAs.
June 20, 200916 yr thanks again ... i still dont see how he is hooking up the outputs tho ... is it positive inside negative shielding? how would you do this with you high level outputsyou got to remember dc flow from plus to minus Only problem here is music is alternating current. If you have DC going to a driver, you have a cone stuck in one direction which = zero sound being produced.
June 20, 200916 yr thanks again ... i still dont see how he is hooking up the outputs tho ... is it positive inside negative shielding? how would you do this with you high level outputsyou got to remember dc flow from plus to minus Only problem here is music is alternating current. If you have DC going to a driver, you have a cone stuck in one direction which = zero sound being produced.one problem there your kinda wrong it's switched dc not ac man big difference. it's switched buy a triggering voltage on the amplifier chip it self. you are right if you got a full blast of dc threw the chip your speaker will do just what you said = zero hertz. see what happens is it read the disk tape or what what ever and transfer that pulse to the rca or the radio amp it's self this is interpreted but the amp as on or a off signal that simple it flickers the chip. causing a 20hz-30,000 hertz pulse i have seen less then 20 hertz so do take that for grated either.
June 20, 200916 yr the one i am borrowing is an OWON HDS1022Mis it this meter ? or close to it? http://www.owon.com.cn/eng/hdsSeries.aspwhat they say to do is connect the probe from channel one to the positive wire with the ten "x" probe used. ignore the alligator clip. and connect it strait to the connection point of the speaker. adjust your y and x axis . so you can read the wave so it fit on the screen. i always start on the highest setting and and work my way lower if i fell it's needed. you can find your owners manual at the link under tech support. i think it was under page 88 of how to use o scope it's the first link i found under tech support.
June 21, 200916 yr thanks again ... i still dont see how he is hooking up the outputs tho ... is it positive inside negative shielding? how would you do this with you high level outputsyou got to remember dc flow from plus to minus Only problem here is music is alternating current. If you have DC going to a driver, you have a cone stuck in one direction which = zero sound being produced.one problem there your kinda wrong it's switched dc not ac man big difference. it's switched buy a triggering voltage on the amplifier chip it self. you are right if you got a full blast of dc threw the chip your speaker will do just what you said = zero hertz. Which is AC. It is alternating, just in many cycles instead of at one cycle.
June 21, 200916 yr thanks again ... i still dont see how he is hooking up the outputs tho ... is it positive inside negative shielding? how would you do this with you high level outputsyou got to remember dc flow from plus to minus Only problem here is music is alternating current. If you have DC going to a driver, you have a cone stuck in one direction which = zero sound being produced.one problem there your kinda wrong it's switched dc not ac man big difference. it's switched buy a triggering voltage on the amplifier chip it self. you are right if you got a full blast of dc threw the chip your speaker will do just what you said = zero hertz. Which is AC. It is alternating, just in many cycles instead of at one cycle.wrong again alternating current power etc.. flow's in two direction's in a conductor there is the positive cycle and the negative cycle if the power never drops below plus or minus 0 volts it's d.c. if it goes negative then positive then it's ac. so what fine school did you get this load of crap from any ways.
June 21, 200916 yr It's cool John.As for my schooling, it's just countless years of being an electrician and hands-on experience. I could let you know how right I am, but I'm not going to waste my time.
