if you take a fully loaded btl D1 coils and wire up one autotek mean machine 1500d to each coil would it put each amp at 1 ohms since its a 1 ohm coil?
ok sweet thanks i was pretty sure just wanted to dbl check...and should i strap those or run one to each coil? and if i do strap, does it need that maxilink think or just do it the regular way
I would strap to a 2 ohm load. Easier to set the gain. As far as the Maxxlink I could not tell you!
Read the owner's manual.
Strap them, not all amps are exactly identical, one may make more power than the other, their could be a time delay between the two amps even if its only 1 ms that could cause distortion.
