Posted June 22, 200917 yr OK i have 2 dp dual 2ohm 15's wired to 2ohm final resistance but now they have gotten quieter and i checked my resistance and it has risen to 3.5ohm any ideas on why this would happen Edited June 22, 200917 yr by 81chevystep
June 22, 200917 yr u must check resistance when the amp is OFF.If you are getting 3.5 with the amp off, then u have the sub wired in series.That... or something is very wrong.
June 22, 200917 yr Author it is with the amp off and it has risen from a final impedance of 2ohm to 3.5ohm in a week or so. maybe its time for a recone?
June 22, 200916 yr Author ok thanks ill check the wiring and if its all good then ill have to order some recones. how much do they run?
June 23, 200916 yr Author ok thanks i pmed him and sent an email, just FYI your voice mail box is full when i tried to call today
September 28, 200916 yr it is with the amp off and it has risen from a final impedance of 2ohm to 3.5ohm in a week or so. maybe its time for a recone?coil down time for recone
