Posted June 22, 200916 yr So I have been thinking, If I wall off behind the second row I should be able to get about 14 and a half cubes. Subs on the outer sides and 200sqin of port in the middle. I would be uprading the electrical, with h/o alt, big 3, and atleast 5 batts(1 up front 4 in the back). Another saz 1500, and a shit ton of deadner. I will be upgrading my fronstage as well. I am hoping to do atleast around 146 or so. That would be double the cone area and double the power, aswell as aupgraded electrical. What do you guys think???? Edited June 22, 200916 yr by mdizzle5472
June 22, 200916 yr i think its a sweet idea but 20sq inches of port isnt that a little small....lol and good luck with the build
June 22, 200916 yr Author i think its a sweet idea but 20sq inches of port isnt that a little small....lol and good luck with the buildLOL edited meant 200
June 22, 200916 yr i think its a sweet idea but 20sq inches of port isnt that a little small....lol and good luck with the buildLOL edited meant 200figured that was just messing wit ya
June 22, 200916 yr Author i think its a sweet idea but 20sq inches of port isnt that a little small....lol and good luck with the buildLOL edited meant 200figured that was just messing wit ya Ha. I thought so.
June 22, 200916 yr Sounds like a Plan... but..... I don't think you'll need all that to do 146 in a Jimmy....I was doing 48's (in the mid 40hz range) in my 4 door Blazer with one Concept cpt 15 in 2.5 cubes tuned 35 hz two 4" areo's sub up ports back... running 4 ohm on a kicker zx2500.1T/L meter head-rest drivers door open (MECA)did roughly the same number sealed on the dash but at a higher freq. blazers/jimmy's are easy to get loud on the mic....
June 22, 200916 yr Author Sounds like a Plan... but..... I don't think you'll need all that to do 146 in a Jimmy....I was doing 48's (in the mid 40hz range) in my 4 door Blazer with one Concept cpt 15 in 2.5 cubes tuned 35 hz two 4" areo's sub up ports back... running 4 ohm on a kicker zx2500.1T/L meter head-rest drivers door open (MECA)did roughly the same number sealed on the dash but at a higher freq. blazers/jimmy's are easy to get loud on the mic....I figured that it would be a little louder than 146 but that was just a rough estimate. I did 141.8 over the weekend with 1 18" XCON, stock electriacal.
June 22, 200916 yr 141?? what freq, what mic, what location..... that's a pretty low score for that equip even with stock electrical.. granted extra juice would help...2dr or 4 dr?
June 23, 200916 yr Author 141?? what freq, what mic, what location..... that's a pretty low score for that equip even with stock electrical.. granted extra juice would help...2dr or 4 dr?4 door tl I think it was aroud 42hz, The guy told me to play like 45 and go up, but wen I went up the numbers got smaller then I went down and they got bigger, If I would have had more time I would have went lower, but whatever it gave me new goals.
June 23, 200916 yr Author Cool plan, now just get it done. I'm goin to start ordering deadner and wire as early as next month. Peice by peice it will be put together, I also nee to completely overhaul the front end of the car itself.
June 23, 200916 yr 141?? what freq, what mic, what location..... that's a pretty low score for that equip even with stock electrical.. granted extra juice would help...2dr or 4 dr?4 door tl I think it was aroud 42hz, The guy told me to play like 45 and go up, but wen I went up the numbers got smaller then I went down and they got bigger, If I would have had more time I would have went lower, but whatever it gave me new goals.whats your box tuned to??Your truck should peak in the mid to high 40hz range... It probably was getting louder lower due to a lower box tuning..***Which you're running a daily setup so that's perfectly fine
June 23, 200916 yr Author 141?? what freq, what mic, what location..... that's a pretty low score for that equip even with stock electrical.. granted extra juice would help...2dr or 4 dr?4 door tl I think it was aroud 42hz, The guy told me to play like 45 and go up, but wen I went up the numbers got smaller then I went down and they got bigger, If I would have had more time I would have went lower, but whatever it gave me new goals.whats your box tuned to??Your truck should peak in the mid to high 40hz range... It probably was getting louder lower due to a lower box tuning..***Which you're running a daily setup so that's perfectly fine It is tuned to 32hz this is why I think the the numbers were low it is in a daily setup. The wall will be tuned for daily aswell, proably around 32-34.
June 24, 200916 yr It's only a little over an hour,if you need some help with this monster!! LOL(I love a good install!)
June 25, 200916 yr Author It's only a little over an hour,if you need some help with this monster!! LOL(I love a good install!)I might have to take you up on that offer, it won't be for a couple months before istart though.
June 25, 200916 yr Admin It's only a little over an hour,if you need some help with this monster!! LOL(I love a good install!)I might have to take you up on that offer, it won't be for a couple months before istart though.This sounds like an unbeatable offer. Jay really knows his audio
June 25, 200916 yr Author It's only a little over an hour,if you need some help with this monster!! LOL(I love a good install!)I might have to take you up on that offer, it won't be for a couple months before istart though.This sounds like an unbeatable offer. Jay really knows his audio Yea i know, i might just have to drive down there and have him help me with this. I'm sure we could get a lot done in a couple of days being down there.
June 25, 200916 yr Oh yeah!I want in on this!!!LOLThe work involved on installs is half the fun!!(The other half comes when you hear the BOOM!)
