Posted June 29, 200917 yr Need help deciding between the sundown saz1000d or the rockford t1000-1bd(09 edition). Will be going on a Fi Bl 15 dual 2. The box will be 4 cubes at 32 hz. Any help is appreciated
June 29, 200917 yr What is cheaper? Everyone on this forum will recommend Sundown. Sundown > Breathing
June 29, 200917 yr IMO. basically which ever one is cheaper. both good. but Sundown's customer service blows Rockford's away by far.EDIT: lmao ^^^ but indeed Edited June 29, 200917 yr by mbarber25
June 29, 200917 yr Author What is cheaper? Everyone on this forum will recommend Sundown. Sundown > Breathingguess i have my answer. ha. the sundown is over $100 dollars cheaper.
June 30, 200917 yr well get the sundown and find some other things you need to complete the setup with the leftover $100. my .02
June 30, 200917 yr Author well get the sundown and find some other things you need to complete the setup with the leftover $100. my .02What other things do you think i need in my setup?
June 30, 200917 yr electrical updates, wiring updates and any installing accessories you may need. Or just use the money for gas so you can ride around and fine tune your sytem or enjoy it, it should take about that long and that amount of gas.
