Posted July 2, 200917 yr O.k. i have a 4.25cft box net volume tune@35hz, with 49 Square inches of port.It used to have Ed 19ov.2 in it , but now i want to upgrade .Deciding between three subs Fi bl 18", Audioque Hdc3 18" or Pap WMD 18. The amp i'm using is eD Nine.1. So which sub would work best?
July 2, 200917 yr O.k. i have a 4.25cft box net volume tune@35hz, with 49 Square inches of port.It used to have Ed 19ov.2 in it , but now i want to upgrade .Deciding between three subs Fi bl 18", Audioque Hdc3 18" or Pap WMD 18. The amp i'm using is eD Nine.1. So which sub would work best?You didn't give us any goals or anything...Try giving us more details or we can't really answer you.P.S. 4.25cft and 49 inches of port is not very much at all for an 18. I would suggest getting a 15 or making a bigger box, but again we don't know if you can make a new box because you didn't specify a car. Edited July 2, 200917 yr by juslivin
July 2, 200917 yr Author O.k. i have a 4.25cft box net volume tune@35hz, with 49 Square inches of port.It used to have Ed 19ov.2 in it , but now i want to upgrade .Deciding between three subs Fi bl 18", Audioque Hdc3 18" or Pap WMD 18. The amp i'm using is eD Nine.1. So which sub would work best?You didn't give us any goals or anything...Try giving us more details or we can't really answer you.P.S. 4.25cft and 49 inches of port is not very much at all for an 18. I would suggest getting a 15 or making a bigger box, but again we don't know if you can make a new box because you didn't specify a car.My goal is to get louder.I wan't something that rocks. this will be daily setup not spl and i don't have the room for a bigger box.
July 2, 200917 yr 4.25 ft^3 is too small for an 18" ported enclosure, now if it was sealed it would be a different story. If you cant go any bigger box wise I would get 1-15" or 2-12" subwoofers, dont choke your subwoofers give them some room to breathe.
July 2, 200917 yr 4.25 ft^3 is too small for an 18" ported enclosure, now if it was sealed it would be a different story. If you cant go any bigger box wise I would get 1-15" or 2-12" subwoofers, dont choke your subwoofers give them some room to breathe.x2
July 2, 200917 yr Does anybody has a fuckin clue on anything at all?Apparently you don't. Keep up this attitude and see where it gets you.
July 2, 200917 yr Does anybody has a fuckin clue on anything at all?Apparently you don't. Keep up this attitude and see where it gets you.again. x2 lol
July 2, 200917 yr Admin I vote FI BL Welcome to SSA, please be courteous to our members here and in return they will to you.
July 2, 200917 yr Out of the three you've chosen,I too would vote for the Fi BL.On the other hand a pair of SSA con 12's in a sealed box may have a louder output.Excellent sound quality to boot!With the space you've provided IMO a ported 18" will sound like azz.It's a little on the small side.Can I ask what type of ride are you putting this into?It may help if it's a common sty;e auto...The suggestions and opinions will be more "fine tuned".
July 3, 200917 yr and if there was an award ceremony for excellent forums this one would win numerous awards... you're lame you cocksucker! go piss on your mother instead Edited July 3, 200917 yr by SSaudio
July 3, 200917 yr Wow. Why ask for help, then? Why don't you go down to Best Buy and ask them what they have to offer you. You should get plenty of courteous help down there.
July 3, 200917 yr Admin He just got a 7 day vacation. Come back with a better attitude or go to ca.com.
July 3, 200917 yr awww was my post too absurd? my bad. but i thought my SSA compliment made it ok? lol
July 3, 200917 yr Admin awww was my post too absurd? my bad. but i thought my SSA compliment made it ok? lolno worries, it just included his post lol. He was a bit crazy IMO for this forum.
July 3, 200917 yr I Didn't Get To See His "Definining Moment" Post. arsehos.Hell, just check through all his posts. About 35% of them are like it.
July 4, 200917 yr I've warned him before or if not was about to and noticed someone else did. Personally I'd make his vacation permanent but considering it is 7 days the first time he acts like a tool again on return it is easy to make a decision.
July 10, 200917 yr Author I've decide on purchasing WMD series sub, it actually came close for my nstall needs.Link>> http://pierceaudioproducts.com/forum/index.php/topic,897.0.htmlBesides according from everyones input , it should sound alot better than eD subs.Should I keep my amps? they are the eD nine.1 class d.I don't have any problems with them, i just wanna know if its putting out true rms power.I thought about buying a SAZ 4000 to power my four 18"s, but since iv'e already on two nine.1s ,it's probably cheaper just to add twomore amps and call it the day.
July 10, 200917 yr Author I notice no one answered my last post, despite all the drama in past i'll will take a chill pill.so please give me positive comments if possible Thanks BassMan 808
July 10, 200917 yr I wouldn't ever run 4 amps when I could run one instead. Doesn't mean it won't work, but far from ideal.
July 11, 200917 yr Author I wouldn't ever run 4 amps when I could run one instead. Doesn't mean it won't work, but far from ideal.I could run those amps strapped, besides it would cheaper for me to add two amps than to start all over from scratch.The SAZ 4500D would be nice to have , i would actually gain more power with four 1200Ds.
July 11, 200917 yr You won't notice a difference unless you double the power, so don't be so quick to start throwing more at it.
