Posted July 7, 200917 yr OK... got a recone for my SPL-15 motor but I have some questions. They might seem dumb but i have never done a recone so i have to ask. 1. the Spiders on the recone are smaller than the original and do not sit in the same spider landing... it does seem to fit fine a couple landings down though..? this OK?2. the coil from the recone is much short than the oginal as well...? 3. I didn't get any shims/spacers or whatever you want ot call them...? what should I use?pics are coming... When i ordered it, it was suppose to be run on a 4Kw @ 1ohm, now it will be on a 2000D @ 1ohm instead... Edited July 7, 200917 yr by k_schutte
