Posted July 10, 200917 yr Would it sound ok to put an Fi SSD in a 1.00 cu.ft. enclosure with a port tuned to 35 hz?
July 10, 200917 yr Author WIll an Fi SSD 12" sound ok in a 1.00 cu.ft. box with a port tuned to 35 hz.
July 10, 200917 yr WIll an Fi SSD 12" sound ok in a 1.00 cu.ft. box with a port tuned to 35 hz.It's a little small. Fi Recommends 1.8-2.5 cubes at 33 Hz.
July 10, 200917 yr Author ok well what would hit harder two twelves in sealed enclosures or 2 10's in ported enclosures?
July 10, 200917 yr way too small for a ported 12, you could squeeze a 10 in that space, or a 12 sealed.
July 10, 200917 yr ok well what would hit harder two twelves in sealed enclosures or 2 10's in ported enclosures?Most likely the 10's, but it depend son the enclosure, amp, subs, vehicle,...etc.
July 10, 200917 yr Author ok i have another question 3 10's sealed or 2 10' porter which will hit harder? using 10" fi ssd subwoofers
July 10, 200917 yr From the way you are posting and your lack of information I'd guess that you don't have enough room for 2 10's ported.
July 10, 200917 yr Author From the way you are posting and your lack of information I'd guess that you don't have enough room for 2 10's ported.well i have a single cab truck... they sell a ported truckbox for 1 10 that is 1 ft3....but i'm guessing 3 10's in a sealed box and for sure 3 12's in a sealed box will hit harder because of the huge difference in cone area...
July 10, 200917 yr Author sorry about the lack of knowledge but i'm trying to learn a little...i'll try to post a little less
July 10, 200917 yr Author lol i posted in two different places for quicker responce probably shouldn't have done that...i've got my decision down if i keep the single cab though so there will be fewer topics from now on
July 10, 200917 yr From the way you are posting and your lack of information I'd guess that you don't have enough room for 2 10's ported.well i have a single cab truck... they sell a ported truckbox for 1 10 that is 1 ft3....but i'm guessing 3 10's in a sealed box and for sure 3 12's in a sealed box will hit harder because of the huge difference in cone area...Your assumption may be seriously flawed. EXACTLY how much space do you have?
July 10, 200917 yr Author From the way you are posting and your lack of information I'd guess that you don't have enough room for 2 10's ported.well i have a single cab truck... they sell a ported truckbox for 1 10 that is 1 ft3....but i'm guessing 3 10's in a sealed box and for sure 3 12's in a sealed box will hit harder because of the huge difference in cone area...Your assumption may be seriously flawed. EXACTLY how much space do you have?i'm not home to tell exactly but the box i found is made by q logic its a behine the seat truck enclosure with 6.5 mounting depth and its ported.....that would acomodate a 10 no problem and it has 1.00 cubic ft. of volume....its 25 inches long and i believe my truck has room for at least 50 inches from side to side behind the seats...and the box is within the specs for a 10...but the other enclosure i'm considering now is a three 12 sealed truck box...i'm guessing that the three twelves would be the better route Edited July 10, 200917 yr by Brandon Frost
July 11, 200917 yr go with one 12, and have a custom box built that will fit your car, there are some people on this forum that will build you the best box money can buy and you will not be dissapointed.oh and dont ever buy a prefab box
