Posted July 10, 200917 yr I need some advice on my amp and hu settings. I have polk momo 6.5's running off of a zx200.4, bridged to 100.2. I have to turn my hu up to around 58 out of 62 for them to be decently loud, but i want them to be louder at a lower volume so i dont clip. I have the gains all the way off. when i go to set the amp up with my dmm, should i just put the volume at 45 out of 62 because the gain setting tutorial says put the volume about 3/4 the way up? Also, there are two gain settings on my amp. would i set each one up independently? And my final question is when i set up my amp, should i set the hu settings such as the high pass filter before i tune it? thanks for the help!!!
July 10, 200917 yr Turn the amp gains up. And yes you should turn on any crossovers before turning the amp gain up. But if you already have them on the amp, no real need to double it up with the head unit crossover.
July 10, 200917 yr Turn the amp gains up. And yes you should turn on any crossovers before turning the amp gain up. But if you already have them on the amp, no real need to double it up with the head unit crossover.you should double up on ur crossover ... it is less frequency for your amp to filter outwithout an oscilloscope you cannot really test where your h/u clips that is why people say to turn it down to 3/4 (better to be safe than sorry) ... yes you need to tune the front and rear gains independently as they are driven separately sometimes making one set of outputs more than the other ... also make sure that when tuning each gain that you test both the outputs going to that gain as one can be slightly higher (always tune to the output with the highest voltage) ... do not tune to the birthed amount of power because your amp will most likely clip ... bring the wattage down some
July 10, 200917 yr Turn the amp gains up. And yes you should turn on any crossovers before turning the amp gain up. But if you already have them on the amp, no real need to double it up with the head unit crossover.you should double up on ur crossover ... it is less frequency for your amp to filter outwithout an oscilloscope you cannot really test where your h/u clips that is why people say to turn it down to 3/4 (better to be safe than sorry) ... yes you need to tune the front and rear gains independently as they are driven separately sometimes making one set of outputs more than the other ... also make sure that when tuning each gain that you test both the outputs going to that gain as one can be slightly higher (always tune to the output with the highest voltage) ... do not tune to the birthed amount of power because your amp will most likely clip ... bring the wattage down someHaving multiple crossovers in the signal chain causes phase issues.
July 10, 200917 yr Turn the amp gains up. And yes you should turn on any crossovers before turning the amp gain up. But if you already have them on the amp, no real need to double it up with the head unit crossover.you should double up on ur crossover ... it is less frequency for your amp to filter outwithout an oscilloscope you cannot really test where your h/u clips that is why people say to turn it down to 3/4 (better to be safe than sorry) ... yes you need to tune the front and rear gains independently as they are driven separately sometimes making one set of outputs more than the other ... also make sure that when tuning each gain that you test both the outputs going to that gain as one can be slightly higher (always tune to the output with the highest voltage) ... do not tune to the birthed amount of power because your amp will most likely clip ... bring the wattage down someHaving multiple crossovers in the signal chain causes phase issues.really? when i worked at boomer mcloud in watertown they told me that it was better to filter them out at both the h/u and amp ... which would be better to do? amp or h/u?
July 10, 200917 yr That depends on the equipment and your ears. If your HU only has a 12 db slope but the amp has an 18 db slope, you may want one or the other. If the head unit only has preset options for crossover points and not variable, that may decide for you if you don't want one of those points.
July 10, 200917 yr Turn the amp gains up. And yes you should turn on any crossovers before turning the amp gain up. But if you already have them on the amp, no real need to double it up with the head unit crossover.you should double up on ur crossover ... it is less frequency for your amp to filter outwithout an oscilloscope you cannot really test where your h/u clips that is why people say to turn it down to 3/4 (better to be safe than sorry) ... yes you need to tune the front and rear gains independently as they are driven separately sometimes making one set of outputs more than the other ... also make sure that when tuning each gain that you test both the outputs going to that gain as one can be slightly higher (always tune to the output with the highest voltage) ... do not tune to the birthed amount of power because your amp will most likely clip ... bring the wattage down someHaving multiple crossovers in the signal chain causes phase issues.really? when i worked at boomer mcloud in watertown they told me that it was better to filter them out at both the h/u and amp ... which would be better to do? amp or h/u?They were confused at boomer mcloudOn top of that regularly using shallow slopes underlapped sounds much better than using steep ones. The point of a crossover isn't to be a brick wall but to allow you to have the best sound possible from the drivers you have based on their limitations.
July 12, 200917 yr Author thanks everyone for the help! i used the tutorial and set my gains properly. my amp does not have a hpf so i just set my hu's hpf to 80hz. i still havent installed my sub and amp yet so ill adjust it when i get there.
