Posted May 8, 200521 yr Hey I have done a lot of research and have heard that the soundsplinter RL-Ps are amazing for both sound quality and sheer power. I am looking for a setup that will bump and will be heard by people outside of the car, yet will still have good sq. I do not want it to bump so much so that my head is going to hurt after 10 minutes though. I was thinking possibly 2 12 Rl-Ps, but didnt know if those would be too loud for what I am looking for. Maybe even 1 15 Rl-P would work too. I would also like to know which type of box would work well with these subs? What type of amplifier would work well with these different setups? Again I want a system that can have some serious power and be heard with good sound quality, but not so much so that it will give me a headache listening to it for 20 minutes. Thanks for all your help. Mike
May 8, 200521 yr Hey I have done a lot of research and have heard that the soundsplinter RL-Ps are amazing for both sound quality and sheer power. I am looking for a setup that will bump and will be heard by people outside of the car, yet will still have good sq. I do not want it to bump so much so that my head is going to hurt after 10 minutes though. I was thinking possibly 2 12 Rl-Ps, but didnt know if those would be too loud for what I am looking for. Maybe even 1 15 Rl-P would work too. I would also like to know which type of box would work well with these subs? What type of amplifier would work well with these different setups? Again I want a system that can have some serious power and be heard with good sound quality, but not so much so that it will give me a headache listening to it for 20 minutes. Thanks for all your help. Mikewell, just about any sub will be heard outside of the vehicle..lol...but, if ur interested in the rl-p's (they are really nice subs!) and going by what u say ur after...a pair of 12" rl-p's sealed (about 2.5ft^3 net for the pair) or a 15 ported (about 2-2.5ft^3, with 25-35in^2 of port tuned between 28-32hz)will both do the trick. i'd recommend about 1200-1500wrms for the pair of 12's and 750-1000wrms for the 15 ported. that will get ya plenty loud and sound great as well...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 8, 200521 yr id go for the pair of 12's, they will hit the lower better and will get a little louder than the 15. im going to get 2 15's soon with a hifonics XX Hercules(2000x1 @1ohm) just my 2 cents.
May 9, 200521 yr Admin to me it sounds like he would be more than fine with a single 12,in a ported tuned low with 500ish watts that will do the trick
May 9, 200521 yr to me it sounds like he would be more than fine with a single 12,in a ported tuned low with 500ish watts that will do the trickbahhhh...(yeah, it'll work)wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 13, 200521 yr Honestly, virtually any single sub setup with even a few hundred watts can easily overpower the front stage and cause hearing damage. Some people like having the bass be 20dB+ louder than the front stage, but these people also wouldn't know what SQ was if it slapped them in the face with a 2x4.I'd recommend just going with a single RL-p 12 or 15. For maximum accuracy, I'd nearly always recommend sticking with a sealed box.As denim said, 500-600w is more than sufficient for musical purposes for either woofer. I'd just disagree with the vented suggestion and just recommend a sealed box, as that's still more than capable of providing sufficient SPL levels for what you seem to want, and will have far superior sub 30Hz frequency response vs a vented enclosure, as well as occupying far less real estate in your trunk.
May 16, 200521 yr uhh,,yeahhehewarbleed, u need to be around more..wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
