Posted July 20, 200917 yr I have a Fi 15inch ssd d-2 on it's way. I have a sundown1200d, at 1ohm can i send 600watts to the sub?i have 4ga and a stock alt and battery.this is why i wana send unded 800watts.i had a audio q2.5 and at 580 watts iwas seeing volt drops at 12.9.
July 20, 200917 yr Admin The standard SSD will handle up to the rms fine, just like every other Fi sub.
July 21, 200917 yr Author The standard SSD will handle up to the rms fine, just like every other Fi sub. great,im gona work on bolting my box down asap. im gona try 600 to the sub
July 21, 200917 yr Author I sure will, I might need to pick up a batt for up front i might go with a powermaster but im not sure . Im gona see how this sub does with only 600 watts and go from there. To bad the weather is kinda sh ity or i would be out there workin on my box. when i had my audioq 2.5 in there the box was jumping around even with a few L brackets. i gota get this box bolted down pretty good. The box is not dubble baffled so im kind worried if the ssd will b moving around. im lookin for new screws and i might get some locktight or somthing to hold this sub down .
July 21, 200917 yr Dude don't worry about overpowering the sub with that amp..I have about 900 on mine and I love it.I have seen people put saz-1500's on a ssd you should be fine.
July 22, 200917 yr Author Dude don't worry about overpowering the sub with that amp..I have about 900 on mine and I love it.I have seen people put saz-1500's on a ssd you should be fine.oh no i wana underpower the sub cuz of my electrical being stock at this time. with my last set up i had a audioq 2.5 ,and at 2 ohms the sub was seeing around 580 watts and at idle with my lights and ac on i was seeing volt drops down to 12.9 or so. So i wana make sure this ssd can play fine with 600 watts not the 800 it calls for. in the past i had 2 12 inch ssd. those 12inch subs seen 900 each all day with no issue. More or less i wana know if i can send 600 watts at one ohm for the time being so i dont get crazy volt drops?
July 22, 200917 yr You shouldn't be seeing big drops with 600 watts.It all depends on your vehicle though..
July 22, 200917 yr Author You shouldn't be seeing big drops with 600 watts.It all depends on your vehicle though..i have a 03 tiburon gt i have a small stock alt and a basic starter battery for now. If i need to get a new front batt i was thinking powermaster .I have used powermaster in the past i was happy with there batt's. I just wanted to make sure the work i have to do to get my box bolted down will be worth it. i wana underpower my sub for some time i hope to not see any issues for the time being. I did not go with a dubble baffle any one think lock tight will work to keep my sub in place? how about diff screws i have allways uses basic wood screws?
