Well i got my system together ( needs some minor adjustments here and there). Running a jvc KD-avx77 to my kicker zx750.1 amp, and to my Fi SSD12 with copper coil option. I wired it in parallel but then my amp went into protection mode and i didnt even really turn up the gain much. Should I wire it in series? My sub has the DVC option
is the ssd dual 2 ohms or dual 4 ohms
dual 4 ohm. i think i need to wire in series...
Fi's only come in dual 1 or dual 2
Since the amp whet into protect the coils are dual 1 and you had it wired to that amp at an .50 an ohm. Run it in series and you get a 2 ohm load and you'll be good.
Edited by sqjeep
x2
I was only thinking about mainstream subs(I meant dual 1 or 2 ohms) :Doh:
Edited by jay-cee
x2
Oh ok thanks, i have the Dual 2. thats what i was thinkin at first
so did wiring in series to 4 ohms work or is your amp still giving you problems.
thats probably not the best amp for that set-up. that amp is only rated at 375 watts at 4 ohms. and running it lower then 2 ohms can blow it.
mine is set-up with BP and D1. wired at 2 ohms. it could handle more but i got a good deal on the amp.
Edited by casedawg350
