Posted August 2, 200917 yr haven't post much but need helpbuilding a sub box and am going to bolt it to the metal behind the back seatis there any other thing i should be doing?any help would be appreciatedsystem is 2 -12 audiopipe txx12ap subs ( been using them for over 3 years) 2 - IA 20.1 ( these subs have never seen both amps ) (these amps are amazing ) 2 extra batteries just for the amps
August 2, 200917 yr Moved to general audio.Is there anything else you should be doing to achieve what goal?
August 2, 200917 yr Author want to hit 150 was at 140 with 1 - kac 9152 ( about 900 watts) with old boxes (tuned at 32 hz)with the 2 -IA20.1 uping the power to 3600 so if you add 3db everytime you double your power then i should hit 146 car freq is 50 hz so i am trying to tune slot port to 50 hz box will be 3 cu ft
August 2, 200917 yr Make some wooden pieces to go between the enclosure and the vehicle side and top walls even with the front baffle. That will seal the subs (I assume you're firing forward) from the rest of the trunk, which effectively lowers the amount of air that the subs have to pressurize in the vehicle. Then use some expanding foam or something to fill in the holes that the wood doesn't quite fill.
August 2, 200917 yr Author was going to put baffle board between backseat and trunk then bolt sub box to baffle board then put mdf on rear deck and porting through thereand yes subs will be facing my seatsdid put expanding foam in trunk lid and i will trying filling every hole but what about any wiring going through ? or should i just put the expanding foam over the wiring?here is some pics to give you an idea what i am doinghttp://www.cardomain.com/ride/2208724/5by the way thanks for the help
