Posted August 4, 200916 yr does anyone know how stable a diamond audio d3 800.1 is at 1 ohm? running a fi q 12" with dual 2 ohm and bp?
August 4, 200916 yr does anyone know how stable a diamond audio d3 800.1 is at 1 ohm? running a fi q 12" with dual 2 ohm and bp?well it can do 800watts at 1 ohm rms so you should be ok as long as you dont crank it but i think u need but you will be fine for now
August 5, 200916 yr Author does anyone know how stable a diamond audio d3 800.1 is at 1 ohm? running a fi q 12" with dual 2 ohm and bp?well it can do 800watts at 1 ohm rms so you should be ok as long as you dont crank it but i think u need but you will be fine for nowIm planning on upgrading later on but for now all i have is the DA
