Posted August 4, 200916 yr what should my electrical look like to support these and the saz-100.4 ... i am debating on whether i want to buy 2 of these or just get the saz-4500d ... right now i have a 260 amp alt by iraggi and the stock was 130 amp ... i was thinking about buying some of the c and d 100 lb batteries (supposed to be comparable to the hc3800) ... how many would i have to buy to support this amount of power ... i understand i would need a bigger alternator but this is the biggest they make for my car and a dual alt setup is near impossible
August 4, 200916 yr Author u dont need larger alt, u would need about 300aH.is that including the front battery? i am assuming no because that would only add up to around 560 amps Edited August 4, 200916 yr by Lucky 76
August 4, 200916 yr Author i also read that you can strap them down to a 1 ohm load so .5 per amp ... is this true? ... if so how much power will they be putting out?
August 6, 200916 yr Admin i also read that you can strap them down to a 1 ohm load so .5 per amp ... is this true? ... if so how much power will they be putting out?I believe they are stable, but not under warranty once run that low.
August 6, 200916 yr i also read that you can strap them down to a 1 ohm load so .5 per amp ... is this true? ... if so how much power will they be putting out?I wouldn't advise running "daily". Jake might be able to advise more.
August 6, 200916 yr man, i run approx 7800w of power on a 250A alt and only 177aH in the rear with stock battery.How does my electrical system stay fine? Simple, you can't listen to it that loud for more than a few seconds, it's all for competition so i dont need to carry around boatloads of reserve.If u show off running at idle or just cant keep it revved at a comp, you need 300aH minimum suggested is my opinion.
August 6, 200916 yr Author man, i run approx 7800w of power on a 250A alt and only 177aH in the rear with stock battery.How does my electrical system stay fine? Simple, you can't listen to it that loud for more than a few seconds, it's all for competition so i dont need to carry around boatloads of reserve.If u show off running at idle or just cant keep it revved at a comp, you need 300aH minimum suggested is my opinion.ill be buying 4 100 lb c and d batteries shortly ... roughly 500 aH ... i am at a stop most of the time because my town sucks ... is that too much?
August 6, 200916 yr with that much, u can sit there for a WHILE blastin it...But you also dont want the alternator to charge a large bank back up or it could overheat.
August 6, 200916 yr Author with that much, u can sit there for a WHILE blastin it...But you also dont want the alternator to charge a large bank back up or it could overheat.that is why i am debating what to do ... i am going to ask jake again and see what he recommends ... i forgot what he said
