August 17, 200917 yr How much "sparkle" do you need on the top end?Since you have a midbass problem and 8" will solve that better than anything else. The only issue is getting it to blend with a tweeter. If you can lose a little sparkle an 8 with a 3" full range would work for a 2 way.
August 17, 200917 yr ^^ What M5 said. I'm using a 2.5in fullrange driver on axis as my "tweeter" and the detail is amazingly good (going from a true tweeter to this). ^^^Plus 8inch mids....... well they ROCK midbass wise if you install them correctly.Jono
