anyone ever did a ported box at about 3.0 cubes @30 hz for an avalanche 15? if so how does it perform? i have alot of power to throw at it so i can build a smaller box
I've got a pair in3.5ft^3 each tuned to 28Hz. They rock the house, then again it is a home setup. They're running off of a Behringer EP2500.
I used mine in my camry, it was 4.0cu^ft @33hz and it was awesome. I had it on a PA 1800d so it was seeing probably around 1000-1100 watts.
What do you consider a lot of power? Much over 1000 watts, and the coil is not going to last long if you are not careful. . .
