Posted May 13, 200521 yr Admin what would you guys prefer to use to smooth out the corners inside a box, putty or bondo, (and which brand)I might grab some resin and hardener for my RL-p box,I want it perfect before the RL-p goes in, I shold probably do some more internal bracing to make it as stiff as possible to preserve as mush SQ as possible
May 13, 200521 yr anything you have on hand.putty will probably be eaiser. bondo you might already have.maybe some resin mixed with sawdust.not a big deal. hell, maybe use expandable foam, and then use sandpaper to cut down whatever you dont need, and then putty over that?
May 14, 200521 yr small pvc pipe, cut in 1/4's...resined in place..wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 14, 200521 yr small pvc pipe, cut in 1/4's...resined in place..wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee x2
