Posted August 14, 200916 yr I am interested in buying a fi btl fully loaded but i have a few ?s. I own a crew cab chevy truck and i wanted to know if i should go with a 12 15 or 18 FI? 1 or 2 ohm? and any tips or suggestions? THANKS!!!
August 14, 200916 yr Size depends on how much room you have to give up. Voice coil depends on the amp you want to buy.
August 14, 200916 yr Author Size depends on how much room you have to give up. Voice coil depends on the amp you want to buy.what is HIXm coil?
August 14, 200916 yr https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154a854cf823a41/shopdata/0070_Tech/0070_Speakers/0010_Tech.BTL/product_overview.shopscript
August 14, 200916 yr I am interested in buying a fi btl fully loaded but i have a few ?s. I own a crew cab chevy truck and i wanted to know if i should go with a 12 15 or 18 FI? 1 or 2 ohm? and any tips or suggestions? THANKS!!!Are you willing to take up the whole crew cab? Amplifier(s) used? Electrical? Goals (SPL or daily)?A little more info from you and we can help alot more.
August 14, 200916 yr Admin Welcome to SSA. You would be better served starting a topic in the Fi Car Audio section.
