Posted August 17, 200917 yr Here is a few pics now that im done. Finally got this damn cam. The alt bracket had to be bent out of the way but it worked. The grounds on the frame are welded on bolts cause I thouht it would be easier. This alt is a BEAST! Thank you Mechman! My power is incredible right now! I hope the regulator isnt set too high. I never touched the adjustment screw and installed it how it was. I thought it came set for you between 14.4-14.9. Is that right? My gauge never gets to 14. It was always over 14 at start up before, but now its just a litle more. Before at 3/4 volume I could get the batt LED light to come on within 5-7 seconds of play. Now...now is a different story.
