SAX-50.4 on sale $200.
* 4/3/2 Channel Bridgeable Class-AB Amplifier
* MOSFET PWM Power Supply
* Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
* 12dB Octave Electronic Crossover Slope
* Variable Subsonic Filter
* Independent 1/2 Channel High Pass Filter Variable with x 10 Range Selectable Switch
* Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
* Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
* Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
* Independent 1/2 and 3/4 Channel Bass Boost Variable Control
* Variable Bass-Boost Frequency Control
* Variable Input Level Control
* Input Sensitivity : 200mV ~ 6V
* Subsonic Filter : 10Hz ~ 500Hz
* Signal Input and Line Out RCA Connectors
* Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
* Tested Voltage & THD: 14.4V & Less than 0.05% THD
* Operating Voltage : DC10V~16V Power Input
* Wired Remote Controller
* MSRP $349 USD
Rated power output
----RMS power, 4 ohm stereo
50W x 4CH
----RMS power, 2 ohm stereo
80W x 4CH
----RMS power, 4 ohm bridged
160W x 2CH
Signal to Noise Ratio >90dB
Low pass frequency crossover
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH3&4)
High Pass Crossover
50Hz~5KHz (CH1&2)
50Hz~500Hz (CH3&4)
Variable Subsonic Filter 10Hz to 500Hz
Bass Boost 0~18dB
Variable Bass-Boost Frequency Control 35Hz to 120Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
THD@RMS Watts <0.1%
Channel Separation 75dB
Fuse Rating 25A x 2
Input Sensitivity Variable 200mV~6V (+/- 5%)
Dimensions 252(W) x 58(H) x 310(L)mm
