I currently have a bl 15 i know its rated at 1000 watts but i have a rockford t1500 and the sub can only be wired to 1 or 4 ohm. can the subwoofer take the whole 1 ohm load from this amp. if i turn the gains down on the amp does that reduce the amount of power going to the sub or will i still feed it the 1500 watts+ either way.
The BL is rated at 1500 watts thermal power handling. Just get your gain right.
Turning the gain down from its actual match to your signal voltage will reduce power output.
