Posted August 29, 200916 yr 1) Low voltage. Most car charging systems aren't equipped to handle the extra strain of amplifiers without some sort of help, if this is the case you may need to add, a capacitor or battery.2) Blown sub. Sometimes when you blow a subwoofer, it can take your amp down with it, most amp's will go in to protect before this happens, but not always.3) Over driving the amp. If you max the gain, and bass boost on your amplifier, you can cause all sorts of problems, including blown fuses.4) Loose or bad connections. Check your connections to the battery, and ground, sometimes a loose connection will play, but cause your amp to over heat by working to hard to produce it's power.5) Bad amp. Could be a factory defect, like a poor soldier joint, or bad component. ________________________________XXXXXXXXXXXXX Edited August 29, 200916 yr by denim more spam links
August 29, 200916 yr Admin Your intentions here are clear. Stop the spam links and gibberish, or IP ban.
