Posted August 30, 200917 yr I have an aftermarket Pioneer HU (AVIC F900BT) and it has a sub control level (from 0 to 6) and bass boost (0 to 6). Would having a bass knob make any difference or is it the same thing as the bass boost on the HU?
August 31, 200917 yr If your pioneer is anything like mine the bass boost ups the bass to the sub and the speakers. Sublevel control is just the sub. A bass knob for an amp can vary from amp to amp.
August 31, 200917 yr Author If your pioneer is anything like mine the bass boost ups the bass to the sub and the speakers. Sublevel control is just the sub. A bass knob for an amp can vary from amp to amp.ok well i have my HPF on 125Hz so no bass is coming out of my speakers. and my 12" bl doesnt get that loud with just the sublevel but once i use the bass boost i gets alot louder... my amp is a sundown sae1200d
August 31, 200917 yr Author It sounds like you need to adjust your gains correctly.my gain was probably 1/8 of the way turned up. is that ok?
August 31, 200917 yr It sounds like you need to adjust your gains correctly.I agree, and make sure everything is adjusted flat or to 0 when setting gains.
August 31, 200917 yr Author It sounds like you need to adjust your gains correctly.I agree, and make sure everything is adjusted flat or to 0 when setting gains.ohhh actually i think my sub level was on the max when they set it...
August 31, 200917 yr It sounds like you need to adjust your gains correctly.my gain was probably 1/8 of the way turned up. is that ok?You should set it with a DMM or Oscope if you can. But 1/8 seems a tad on the low side unless you have a line driver.
August 31, 200917 yr It sounds like you need to adjust your gains correctly.my gain was probably 1/8 of the way turned up. is that ok?Nope. You need to set it the RIGHT way.
August 31, 200917 yr Author It sounds like you need to adjust your gains correctly.my gain was probably 1/8 of the way turned up. is that ok?Nope. You need to set it the RIGHT way.ha i didnt set it! i got professionals to install it! but when i got my amp back to send it back for repair i saw that it was set at about 1/8 of the way up
August 31, 200917 yr It sounds like you need to adjust your gains correctly.my gain was probably 1/8 of the way turned up. is that ok?Nope. You need to set it the RIGHT way.ha i didnt set it! i got professionals to install it! but when i got my amp back to send it back for repair i saw that it was set at about 1/8 of the way upYou need to change that then
August 31, 200917 yr Author It sounds like you need to adjust your gains correctly.my gain was probably 1/8 of the way turned up. is that ok?Nope. You need to set it the RIGHT way.ha i didnt set it! i got professionals to install it! but when i got my amp back to send it back for repair i saw that it was set at about 1/8 of the way upYou need to change that then alright ill talk to them about that... but when they hook up the sub should i make sure that the sub level is at 0?
August 31, 200917 yr Why don't you just do it yourself? No need to pay for something you can easily do.
August 31, 200917 yr Author Why don't you just do it yourself? No need to pay for something you can easily do.it should be free but if they do try to charge me i will do it myself
August 31, 200917 yr Why don't you just do it yourself? No need to pay for something you can easily do.it should be free but if they do try to charge me i will do it myselfMake sure they do it right...do YOU know how to do it?
August 31, 200917 yr Put the bass boost at 0. That is an actual boost at a certain frequency that will likely do absolutely no good for your system, and increase the chance of harm. The sub level setting, however, adjusts the overall signal strength to the sub amplifier. When you set the gain you'll likely want this at +6. That way you can adjust the sub's volume relative to the rest of your interior speakers from the drivers seat.A bass knob that comes with an amplifier can either be a bass boost or a gain control. Bass boost is the same as the bass boost on the head unit, generally not a good idea to use at all. But the gain control is like the sub level setting on the head unit and adjusts the total signal strength. That is the appropriate control to use.If the shop set your gain with the bass boost all the way up, they did a terrible job.
August 31, 200917 yr Author Why don't you just do it yourself? No need to pay for something you can easily do.it should be free but if they do try to charge me i will do it myselfMake sure they do it right...do YOU know how to do it?haha yeah i think so
August 31, 200917 yr Author Put the bass boost at 0. That is an actual boost at a certain frequency that will likely do absolutely no good for your system, and increase the chance of harm. The sub level setting, however, adjusts the overall signal strength to the sub amplifier. When you set the gain you'll likely want this at +6. That way you can adjust the sub's volume relative to the rest of your interior speakers from the drivers seat.A bass knob that comes with an amplifier can either be a bass boost or a gain control. Bass boost is the same as the bass boost on the head unit, generally not a good idea to use at all. But the gain control is like the sub level setting on the head unit and adjusts the total signal strength. That is the appropriate control to use.If the shop set your gain with the bass boost all the way up, they did a terrible job.no the shop had the bass boost at 0 when they set the gain but had the sub level at 6... but why would i want to have it at 6 when i set it? i thought it should be at 0 when i set the gain?
September 1, 200917 yr That way you have the ability to turn the sub down. If you set the gain with the level at 0 then increase the level to +6, you'll be clipping the amp.
