Posted August 31, 200917 yr ill do the best i can to explain. my buddy just got some memphis subs the mclass 12s he has about 400 watts going to each the day after he got them one started smoking and then quit it still works but makes a clicking noise i took it out and took a look at it but didnt see anything wrong does anyone know what this could be?
August 31, 200917 yr ill do the best i can to explain. my buddy just got some memphis subs the mclass 12s he has about 400 watts going to each the day after he got them one started smoking and then quit it still works but makes a clicking noise i took it out and took a look at it but didnt see anything wrong does anyone know what this could be?mclass subs aren't designed for 400wrms daily. although in the proper enclosure, with gains set right, they might live for awhie. my guess is they were overdriven to the point of failure. that sub making noise is toast. smoking coil isn't a good thing.time for stronger subs.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
August 31, 200917 yr Author thats what i told him i checked his gains they werent set overly high but the amp was doing alot more than the subs could handle after i did some research
August 31, 200917 yr Author lol thats what i figured i told him he needed to step up a lil but the amp was actually putting around 500 to each sub i told him to step up to m3s what yall think?
August 31, 200917 yr lol thats what i figured i told him he needed to step up a lil but the amp was actually putting around 500 to each sub i told him to step up to m3s what yall think?Tell ya boy to check out the Sundown Audio SA-12"s(600RMS), some Incriminator Lethal Injections 12"(600RMS) or the SSA DCONS 12"s(300RMS) subs also on the http://www.soundsolutionsaudio.com/store/.
August 31, 200917 yr Author im gonna try to do that tonight and see what he says depending on what the shop does for the sub he has thats messed up
