Posted September 5, 200916 yr I currently have 2 fi q 15s in my dakota and am now getting a Ram 1500. Is it possible to get these sub in there or will i have to settle for what everone else is doing and go with two 10's?
September 5, 200916 yr single or extended cab?extended cab, yes.single no unless you do a blow through.
September 5, 200916 yr Author Am getting the Quad Cab. So it is possible, Is it possible for you to send a drawing of how i can do this? Thanks
September 6, 200916 yr quad cab for sure, but you do know that you would have to wall it and everything, and as stated above it will be a lot of work.
September 6, 200916 yr quad cab for sure, but you do know that you would have to wall it and everything, and as stated above it will be a lot of work.wouldn't think he'd have to wall it. remove the seats and build over what's left definitely. still not a "straight up" build though. good bit of work .
