Posted September 10, 200916 yr Can you please help here is my box dimensions Box width:51Box height:21Top box depth:21Bottom box depth:21Wood thickness: 0.75i want and tuned to 34 to 30hz not sure which what do you guys think need to know soon got a guy designing me a box i told him 34 but want these to hit hard do you think 30 or 32 is better
September 10, 200916 yr Author What type of music you listen to?What kind of subs are they?95% rap and there 15s Lethal injections
September 10, 200916 yr If he builds the box to those dimensions, you will have roughly 10 cubes. That is waaaay too big for those subs. You should be looking for around 6.5-7 cubes, and I would tune to 32hz
September 10, 200916 yr 10^3' is way to big! I run mine at 7^3' tuned to 35HZ. With your rap listening I would recommend between 30-33hz tuning.
September 10, 200916 yr Author 10^3' is way to big! I run mine at 7^3' tuned to 35HZ. With your rap listening I would recommend between 30-33hz tuning.What will happen if the box is to big? and am tuning it to 32hz
September 10, 200916 yr Power handling goes down, subs can sound loose and muddy, subs can unload, etc. etc. etc.
September 11, 200916 yr Author Power handling goes down, subs can sound loose and muddy, subs can unload, etc. etc. etc.ok here are the new dimensions i started not a huge differences but should this be a small enough box49 inches long- 18inches tall- 21 inches deepalso running 3/4 MDF board and am putting in 45s which should take some room What is my cubic feet on this box
September 11, 200916 yr Power handling goes down, subs can sound loose and muddy, subs can unload, etc. etc. etc.ok here are the new dimensions i started not a huge differences but should this be a small enough box49 inches long- 18inches tall- 21 inches deepalso running 3/4 MDF board and am putting in 45s which should take some room What is my cubic feet on this boxLooks to be 8.36 cubic feet after speaker displacement
September 11, 200916 yr Power handling goes down, subs can sound loose and muddy, subs can unload, etc. etc. etc.ok here are the new dimensions i started not a huge differences but should this be a small enough box49 inches long- 18inches tall- 21 inches deepalso running 3/4 MDF board and am putting in 45s which should take some room What is my cubic feet on this boxTry the12volt.com cause they have a good little calc on there. You can also try the RE calc as it has a ton more info about box specs.
September 11, 200916 yr Author 8.36 should be perfect right tuned two 32hz i think it will be good but its my first box build so hope i don't screw up.here is a link to what will be my slow build wont get subs for two weekshttp://www.****/forum/showthread.php?t=17369 Edited September 11, 200916 yr by .AJ.
September 12, 200916 yr If he builds the box to those dimensions, you will have roughly 10 cubes. That is waaaay too big for those subs. You should be looking for around 6.5-7 cubes, and I would tune to 32hzi 2nd this coment agreee 100%
September 12, 200916 yr Author If he builds the box to those dimensions, you will have roughly 10 cubes. That is waaaay too big for those subs. You should be looking for around 6.5-7 cubes, and I would tune to 32hzi 2nd this coment agreee 100%Like i said i down sized the box now it is 8.36 cubic feet but one last question do these subs play better straight up and down or on the side or does not make a differences
September 12, 200916 yr If he builds the box to those dimensions, you will have roughly 10 cubes. That is waaaay too big for those subs. You should be looking for around 6.5-7 cubes, and I would tune to 32hzi 2nd this coment agreee 100%Like i said i down sized the box now it is 8.36 cubic feet but one last question do these subs play better straight up and down or on the side or does not make a differencesNot quite following you! Straight up and down? As in 1 woofer on top of the other on the same panel facing forward?
September 12, 200916 yr Author If he builds the box to those dimensions, you will have roughly 10 cubes. That is waaaay too big for those subs. You should be looking for around 6.5-7 cubes, and I would tune to 32hzi 2nd this coment agreee 100%Like i said i down sized the box now it is 8.36 cubic feet but one last question do these subs play better straight up and down or on the side or does not make a differencesNot quite following you! Straight up and down? As in 1 woofer on top of the other on the same panel facing forward?i mean both subs facing up toward my roof or on there side facing my front windshield also i see you got 2 15 Li want are you running them with and got any vids of them?
September 12, 200916 yr No vids. But I run mine facing forward along with the port.What kind of vehicle do you have?Link to my build log
September 15, 200916 yr Author If he builds the box to those dimensions, you will have roughly 10 cubes. That is waaaay too big for those subs. You should be looking for around 6.5-7 cubes, and I would tune to 32hzi 2nd this coment agreee 100%Like i said i down sized the box now it is 8.36 cubic feet but one last question do these subs play better straight up and down or on the side or does not make a differencesNot quite following you! Straight up and down? As in 1 woofer on top of the other on the same panel facing forward?NM am going to shoot them up toward the roof but do you guys know how long shipping is from SSA i ordered Some Li's about 1 week ago and am of course very excited and want to get them here yesterday because the only other sub i had was a insignia 12 pushing supposedly 600rms now am going to be pushing 1200 in a good box i hope. Also was wondering if anyone could post some vids of there Li's and what rms your runnibg cant really seem to find much on them
