So if I get a DVC 2ohm BTL that means there are two voice coils, which just ONE can handle 2kwrms correct? So if I hook up 2kwrms to each, shouldnt that work? Or lets say 1500 on each coil for less heat?
Yes yes I understand Im retarded, but you never learn if you never ask :)
P.s. figured out my other question..
Edited by forsellb
no, 1000 per coil or 2000 per whole sub.
So I was running two subs before, 500RMS, 1500 peak with DVC and I only hooked up one coil and ran about 600RMS through it.. So if its 500RMS that means 250 per coil?
Right.
