Posted September 22, 200916 yr Okay so i got the 2 12" Fi SSD and i have a 1800 Watt MA Audio 2 Channel AmpThe subs are dual 1 ohm and i was wondering how would i need to wire them?
September 22, 200916 yr This is for EACH sub:The sub has 2 voice coils (two positive and two negative connections). Run a piece of wire from the positive of coil 1 to the negative of coil 2.Then wire the negative on coil 1 from the sub to the amp and the positive on coil 2 from the sub to the ampWire one sub to each channel of the amp. This will give you a 2 ohm per channel load on the amp.Brian
September 26, 200916 yr This is for EACH sub:The sub has 2 voice coils (two positive and two negative connections). Run a piece of wire from the positive of coil 1 to the negative of coil 2.Then wire the negative on coil 1 from the sub to the amp and the positive on coil 2 from the sub to the ampWire one sub to each channel of the amp. This will give you a 2 ohm per channel load on the amp.Brianx2
