September 30, 200916 yr yes u can, they need to be gain matched so dont just set the gain in the same position on both amps!question - are those amps 1 or 2 ohm stable?
September 30, 200916 yr Author both im running the one i have now at 1 ohm which gives me about 1200 watts or so it says
September 30, 200916 yr Author 400W x 1 @ 4O mono750W x 1 @ 2O mono1200W x 1 @ 1O monoTotal Harmonic Distortion: 0.03Frequency Response: 20~250Power Band Width (Frequency Response): 20~500 HzCrossover Frequency: 40~250 Hz - 15~40 dB 40~1K HzDamping Factor: 100Dimensions: 2.5 x 10.5 x 14.5 InchesFuse Rating: 30A x 3Power Voltage Range: 12~16VHigh efficiency Class D design(1D/2D/3D)Output stages utilize high-current MOSFET devicesHigh speed, audio-grade components in all low-level stagesActive Constant Current Bias Tracking CircuitPlatinum-plated RCA inputs and connectorsWide range of sensitivity accepts signal from any head unit24dB/octave Subsonic Crossover24dB/octave Lowpass CrossoverTrue Line OutputAuto Bridge featureShort Circuit Protectionthats the specs on it
September 30, 200916 yr so u need a powerful dual 1 ohm 18.. there's the Fi BTL, AQ HDC3 Aluminum Coil, Nightshade, DC Level4 XL, IA Death Penalty...
September 30, 200916 yr Author hmm im going to look into those ill be back on here tonight and let u know my choice thanks for helping
September 30, 200916 yr Author ok let me ask u this if i use both amps like i plan on doing at the one ohm is that gonna give me a total of say 2400 watts on the sub? Edited September 30, 200916 yr by bjballar41
September 30, 200916 yr yes it will and all the subs i named off WILL handle the power fine as long as you set the amp's up right and not clip the hell out of them all the time.
September 30, 200916 yr Author ok just making sure i understand everything right. another question i have is how to i gain match the amps?
September 30, 200916 yr you must have an oscope to properly setup an amp in the first place.If u do not have one of those, then u can match them via multimeter to make sure they both put out the exact same voltage on the speaker terminals.Note - do this with a test tone playing.as an example and a somewhat guesstimate of what u should be lookin for-35v is what it should be if it was actually seeing a true 1 ohm load during play but it wont so the voltage reading will probably be higher... Not suppose to be but that's just what happens typically with amps.So.. as an example, instead of aiming for 35v, aim for somethin like 43v even on both amps. It's gonna get LouD, trust me.You are not to this stage yet and will have forgotten what i tell u here when u get there. Come back and ask or just PM me when the time comes! You are gonna need 2 DMMs (digital multimeters) to do this and the amps need to be adjusted together, not individually.
September 30, 200916 yr Author i watched a video of ***** ***** using an oscope but it was along time ago. so doing all this with the amp sounds hard is it or is it easier than it sounds? ill be sure to keep that in mind about coming back to u cause it will be awhile
September 30, 200916 yr it's not hard, lol. Basically, u just set your head unit up and all that, turn both gains on amps just under half way up... let the tone start playing but have the head unit volume up like half way then have someone else turn the volume up so u know the sub can take it without moving too much then turn it back down, the hu's volume. Now, you turn it up to it's maximum listening level, blast the tone and immediately start adjusting the gains on both amps til they output the exact same voltage. You must be turning them together as turning just one will effect the other.Once they are pretty damn close, you are done. I would be aiming for around 43v per amp during playback.If u just cant do it for some reason, pay the $115 and buy u a Maxxlink and it'll do it for you.
September 30, 200916 yr Author sweet thats some great info there thanks a ton. im leaning towards the dc level 4xl, fi btl, and ia dp. is there anything i need to know about them?
September 30, 200916 yr Author lol great info lol smartass lol so pretty much anyway i go is a good option is what ur saying lol
September 30, 200916 yr i wont recommend some great subs and some shitty shitty subs... I recommend what i'd run personally.
September 30, 200916 yr Author ahhh thats good a good clean honest guy im glad ur like that do u know the price of a dc level4xl or should i call?
September 30, 200916 yr ahhh thats good a good clean honest guy im glad ur like that do u know the price of a dc level4xl or should i call?email Rusty at [email protected] or call the shop 1-775-425-5700.
October 1, 200916 yr Author well it looks like its down to the fi btl, dc lvl4xl, or the ia dp all 18 inch anyone have any comments about them ill be running 2400 watts from two md1d usamps.
October 3, 200916 yr Author bump on this its gonna be daily so its music only so its gotta sound good i think im leaning towards the ia or fi
