Posted September 26, 200917 yr I have a 99 Siverado 3 door. What I want to do is take back seat out and build a box for subs so they will be behind driver seat stacked on top of each other. Take back seat and get cut so I will still have a half seat back there. No one in my area wants to deal with it. Is this a good idea? I just want my trunk to be able to carry 3 people instead of just 2. Would a ported box still be okay on one side of truck?
September 26, 200917 yr Cutting your seat is stupid, better off finding someone to make you a custom seat. Expect to drop $500-$1500 on it though. Not so sure it would be cheaper to "cut" your current one though.
September 26, 200917 yr just build your box over top the seat if you are that desperate... Edited September 26, 200917 yr by lithium
September 26, 200917 yr Author I didn't mean just chop in half and then bolt it back in. I meant , get it customized so it would look factory. Or find a shorter seat , like a 60/40 bench seat , like from a tahoe or something and just use a the 60 or 40 part, which ever fit the best.
September 26, 200917 yr I didn't mean just chop in half and then bolt it back in. I meant , get it customized so it would look factory. Or find a shorter seat , like a 60/40 bench seat , like from a tahoe or something and just use a the 60 or 40 part, which ever fit the best.Heres my 2cents, do you really wanna go through all that just for one more seat? And if so what if you buy another 'captains' seat and mount it back there instead of having half a bench?
September 26, 200917 yr What size and how many woofers are you planning on? Stacked on top of each other like a wall?
September 26, 200917 yr Author I'm only going to do 2 -12's. The captain's chair sounds good if it will fit back there, have to look into that. Edited September 26, 200917 yr by rak_24540
September 26, 200917 yr look at thor's set up, He is pulling serious numbers with 2 DC 10's.2 10's / 4 8's and keep you whole seat.
