April 5, 201312 yr Author I'm fighting an electrical problem with it atm. Theres a wire running to the front that you are supposed to tap into an ignition source. well for some reason that wire is not working. I have no clue what is wrong with the wire at all. It has power all the way through the wire front to back but for some reason its not telling the air ride system to turn on. It reads 14.9 front to back in various spots. But if i take the wire in the back and hook it straight to battery the system turns on. The only thing I can think of is maybe 14.9 is too high of voltage for it? Since the battery I had it hooked to was only 12.7 volts. Which if thats the case seems awefully stupid but I can't really think of what else it is.
April 5, 201312 yr lol... I like it... just drive straight... EVERYWHERE! Sadly its not drivable that low lol. Can't turn the wheel at all.
April 13, 201312 yr Author found a leak in the tank, along with 2 others but all good now.the door pods look like shit atm. I had to throw them in to get ready for a comp next week and this will give me an idea on how they work out before i get too into it. will be a lot more "prettying" up after the comp in a week. Just trying to get where I can get points and atm I have no garage and the rain is killing me.
April 13, 201312 yr Rain in your area? No way Looking good, cannot wait to see what numbers it will do.
March 26, 201412 yr Sadly its not drivable that low lol. Can't turn the wheel at all. where are you man!!!
March 26, 201412 yr I've been working on this rebuild, sorry I haven't had much time uploading images.
March 26, 201412 yr YOU SOB! lol no but seriously man, can't wait until you get this thing up and running! 58s on music!
June 20, 201411 yr Author Well since this hasn't been updated in a while except senchez stealing my pictures so here goes..... Front stage consisting of 2 b2 hntt tweeters, 4 b2 hn6 pa mids, and 2 b2 es8 subs for midbass. Powered by 2 h class b2 quattros (4x150) and a b2 quota (1k) for the midbass which is not pictured. Some of the wood for the new wall build, the 4th didnt work out as well as I had hoped. This will make for a much stronger wall.Shell made out of 3"x12" boards I got from work. New head unit. I love this thing. With a maestro unit I can pull up info from my odb2 Also this unit allows mhl and slimport use so i can mirror my android phones.
June 20, 201411 yr Author pretty much all wiring and accesories are sky high (ordered through the SSA Store) A new volt meter I wanted to try out. You can customize this in so many ways and have many different inputs and not just volts. Here is how the batts and amps look atm. This will be changed soon as tomorrow 2 more b2 m1s will be showing up. So I'll have 4 of the b2 m1s and 7 amps total.Sky high 2/0 with Projectdb reducers and buss bars. Cutting the boards....my saw hated me. What we started with...
June 20, 201411 yr Author Started with the back wall And the floor And the sides Luckily I had a port monkey willing to climb in the wall with the subs installed but no port
June 20, 201411 yr Author The door panels I had made, They ended up being a huge fail as the metal b2 signs I made wouldnt stick to the plexi no matter what tricks and glues I tried to use. Also a miscalculation on my part made the flannel part stick out to much on the bottom, catching the doors. Needless to say I had to jigsaw the crap out of them to get them to work which really sucks because I liked them so much. And I ended up plasti dipping the toaster And thats about where I'm at atm. Will be pulling the front baffles off again and cutting out the wheel wells to glass theym so they are flatter and not just giant blocks. And possibly move the baffle back so I have more leg room. And theres lots more work left to do.
