Posted September 27, 200915 yr so i was bored today and was looking around a came across this sub a soundstrem xxx 18 inch ill post the link but it says 10000 watts rms is that true i mean seriously. take a look. http://www.woofersetc.com/p7740/XXX18--Soundstream-18"-XXX-Subwoofer.htm
September 27, 200915 yr they've been around for a good 2yrs that i know of at least.They can handle a good 4-6kw for daily
September 27, 200915 yr Author i might of came across it awhile back but i usually dont look at soundstream i dont want them i just wanted to know if the 10000 watts rms was true
September 27, 200915 yr im 100% sure that it can do 10k competing.http://soundstream.com/AudioProducts/Subwoofers/xxx.htm
September 27, 200915 yr I haven't seen the 18's but I just installed 2 15's in my car yesterday. I have alot of tweaking to do but my initial thoughts are my ears hurt. I only have 2200w to each for daily but they aren't moving to much but seems loud without turning the volume up. I had a very hard time moving the cone at all with my bare hand. The pain in my back today says they are beastly. After I get them broken in and do some tests I'll make up a review of how they perform so far so good tho.
September 27, 200915 yr you'll be lucky to ever get them moving a lot.They expect a large amount of power so unless your box is extremely large or u are running 10kw+, the suspension is gonna stay stiff for a long time.
September 27, 200915 yr you'll be lucky to ever get them moving a lot.They expect a large amount of power so unless your box is extremely large or u are running 10kw+, the suspension is gonna stay stiff for a long time.Would you say I should give up on "breaking them in"? The best I will be giving them is 3000wrms (and some change maybe) on burps. Oh and they are in a 6 cubes net for now, in a few months I'll be putting them in 9 cubes net.
September 28, 200915 yr you should start with the largest box possible then start shrinking it until u dont gain any more. Same way with your port too in terms of length.
October 7, 200915 yr i might of came across it awhile back but i usually dont look at soundstream i dont want them i just wanted to know if the 10000 watts rms was trueSBN 2009Virgil Williams• 1987 Rabbit (soundstream XXX-18 &soundstream XXX15K)• Ultimate 1 – 1st (169.9 dB)• 169.6, then 169.9, then 170.3, then 170.2There's your proof or power right there. a single 18 and 15,000 watts.
October 7, 200915 yr i might of came across it awhile back but i usually dont look at soundstream i dont want them i just wanted to know if the 10000 watts rms was trueSBN 2009Virgil Williams• 1987 Rabbit (soundstream XXX-18 &soundstream XXX15K)• Ultimate 1 – 1st (169.9 dB)• 169.6, then 169.9, then 170.3, then 170.2There's your proof or power right there. a single 18 and 15,000 watts.It took on an additional 5,000rms, can you say ridiculous. I was always interested in Soundstream Subs especially the Tarantula series but always picked Kicker CVX's over them(not saying I made the best decision since I never heard any of Soundstreams subs), just wondering how good are Soundstream subs.
October 8, 200915 yr i might of came across it awhile back but i usually dont look at soundstream i dont want them i just wanted to know if the 10000 watts rms was trueSBN 2009Virgil Williams• 1987 Rabbit (soundstream XXX-18 &soundstream XXX15K)• Ultimate 1 – 1st (169.9 dB)• 169.6, then 169.9, then 170.3, then 170.2There's your proof or power right there. a single 18 and 15,000 watts.It took on an additional 5,000rms, can you say ridiculous. I was always interested in Soundstream Subs especially the Tarantula series but always picked Kicker CVX's over them(not saying I made the best decision since I never heard any of Soundstreams subs), just wondering how good are Soundstream subs.my new setup is going to be 2 soundstream xxx-18's and 2 xxx-6500d's. i've seen these things handle an atomic 7000.1 daily no problem.
