Posted September 28, 200917 yr I have been trying to wire up my subs. I have two Mach 5 Audio SPL12s hooked to a Audiopipe AP3000.1D. I am using 8 gauge wire to go from the amp to the subs. However I cannot get the wire to stay in these terminals. I put one 8 gauge wire in and tightened them all the way up and the wire still didn't really stay in there.So what I came up with is this:I took the nut off where the tinsel lead goes to the terminal, then put a length of 8 gauge with a ring connector on it.Will this cause any problems? I don't have both subs done yet, so it is not hard to revert.I find these terminals a pain in the ass!its sort of like what DD has done with their subs.
October 11, 200917 yr Author If it works for you then great.If I had a computer I'd throw up some pictures.Is there any particular reason why the wire falls out? Are the terminals ment for wire larger than 8 gauge?
October 11, 200917 yr instead of twisting the wire try pulling it to make it more even and flat, i had the same problems attempting to twist it, it just made it bigger than just pulling on it straight.I hope that makes sense lol.
October 11, 200916 yr When you think its tight wiggle the wire side to side, then tighten again. Keep doing this till you can't tighten it anymore. (about 3-4 times) These terminals are the devil.
