Posted May 31, 200520 yr Admin I have done my reading but I still do not know enough,I want to learn how to design them and the strengths and weakness of each.I hope to design and build one of these for an RL-i 8
May 31, 200520 yr Folded horns are vastly easier to build than a mass-loaded T-line, as no accurate modeling or equations are availible. Every good t-line out there has been built, re-built, and tweaked with the stuffing and line length to get it in top notch shape. They're tricky little beasts. http://www.t-linespeakers.org would be a good place to look.Also, DIYAudio's Full Range forum (where I'm still a newbie, heh) will be very helpful to you: http://www.diyaudio.com/forums/forumdispla...p?s=&forumid=51
June 1, 200520 yr .....http://www.t-linespeakers.org would be a good place to look.....<{POST_SNAPBACK}>Great site... been studying on & off for a year. LoL
June 1, 200520 yr I think I might start playing around with them. Very tedious to design from what I understand. My kind of project.
June 1, 200520 yr After seeing that 10 biggest lies in car audio thread, I'd think you were mentally exhausted not proving your point, Effendi. =p To answer the thread, you will probably need about 8-12 cubes NET for a folded horn enclosure for an 8 inch driver, so you don't have a choice as to which you would put in a car. Observe:
June 2, 200520 yr Author Admin well I have an explorer and it would be funny to build a box that went form the B pillar back
June 5, 200520 yr Look into Decware's web site. They have a lot of nice horn enclosures designed for car audio. While the output compared to a normal folded horn sucks ass, they appearantly can still kill bandpass enclosures, and have taken home a few trophies in the process.www.decware.com
June 7, 200520 yr I found my copy of a 1936 article about building an "exponential" horn for a single 8 inch driver. I'll scan it tonight and upload the pages.
June 7, 200520 yr Author Admin I found my copy of a 1936 article about building an "exponential" horn for a single 8 inch driver. I'll scan it tonight and upload the pages.nice
June 7, 200520 yr To answer the thread, you will probably need about 8-12 cubes NET for a folded horn enclosure for an 8 inch driver, so you don't have a choice as to which you would put in a car.I would I'm thinking what a 12-15 driver in such a horn would do in my vehicle off a kW...and it scares me. But it's something to think about for the future
June 7, 200520 yr how big would the smallest horn be for a 12-15? and would a small horn be better than a decent size ported?
June 7, 200520 yr hey denim if u plan on doing a t-line box u need 2 make sure that your sub has a low q and a low fs 80
June 8, 200520 yr The smallest in my findings would be the Wicked One by Decware. The absolute smallest would be 6 cubes gross, ideally 9 cubes gross. Like I said, it won't hold a candle to a full size 28 cube folded horn, but it will kill most ported / bandpass enclosures.
June 9, 200520 yr The smallest in my findings would be the Wicked One by Decware. The absolute smallest would be 6 cubes gross, ideally 9 cubes gross. Like I said, it won't hold a candle to a full size 28 cube folded horn, but it will kill most ported / bandpass enclosures.<{POST_SNAPBACK}>how bout 1-15 8ft gross horn vs. 2-15 6ft net @ 30Hz ported?
June 9, 200520 yr Probably not. The Wicked one is at best 9 cubes for two tens. A 15 in 8 cubes would be like trying to port a 15 with less than 2 cubes net.
July 7, 200520 yr I have a WickedOne for 12's 36x30x14.5 outside deminsions.To futher thoughts on horns,http://www.speakerplans.comandhttp://www.billfitzmaurice.com/plans/defau...85a48680a17bfa4
November 9, 200717 yr i want to build the X-1 for my ford Explorer>>> check it outhttp://www.speakerplans.com/
November 9, 200717 yr I'm not a fan of that low end rolloff...looks like a much better PA box than hi fi.
November 9, 200717 yr Ahhhhhhh Yes but did you see where it Peeks ??? 31 to 119Hz my ford Explorer does best between 52&55Hz... perfect....im thinking of trying the single sub thing... and in my Suv that thing would be a wall Edited November 9, 200717 yr by Lord Baccus
