Posted October 7, 200917 yr Pic of Prototype surround for DC lvl 5 Thorshammer 10 Edited October 7, 200917 yr by Thorshammer
October 8, 200917 yr What a huge surround for 10", I know these will freaking pound and push some air.
October 8, 200917 yr Author Nice. Whats the Sd compared to the regular 10's?Dave what do you mean by Sd?
October 8, 200917 yr I might be wrong, but isn't the SD the actual cone area? Just wondering how much more cone there is with the skinnier surround.
October 8, 200917 yr I might be wrong, but isn't the SD the actual cone area? Just wondering how much more cone there is with the skinnier surround.The Sd can be two things (speaker displacement or speaker surface diameter/cone area), so yeah your right.
October 8, 200917 yr the SD cannot be 2 things, displacement is the speaker displacement.....and SD = surface Diameter, which iirc is the cone diameter and up to half of the surround......this would be just a little bit larger than the regular surround, its the added throw potential that will allow Rob to do more numbers with these subs.that and a wee bit smaller port.
October 9, 200917 yr Author the SD cannot be 2 things, displacement is the speaker displacement.....and SD = surface Diameter, which iirc is the cone diameter and up to half of the surround......this would be just a little bit larger than the regular surround, its the added throw potential that will allow Rob to do more numbers with these subs.that and a wee bit smaller port.But I don't wanna smaller port
