October 16, 200917 yr Author okay , gotta spend time with wifey, might have permission slip signed by tonight, lol.
October 16, 200917 yr yea, i got the pm few days ago. The volume is correct, the tuning isn't simply because of this-When using a slot port, one wall of the box is used as the port wall the entire time.. When calculating port length, once you measure from the outside in, once the prot ends on the inside, take the width(the smallest dimension) and divide by 2 then add this number to the port length for the added acoustical length...So let's say your port length needs to be 30" long.. your box is 15" deep internally using single baffle with 4" of port width internally...So, from baffle to back of wall is 15.75" deep then the thickness of that port wall is .75" so 16.5" deep now.. So we need 13.5" more... Instead of running the 13.5" long, you run 11.5" long.. The port width is 4" so divide by 2 = 2". 2" + 11.5" = 13.5"
October 16, 200917 yr The port is on the bottom right corner... With the box being 40+ wide inches and the port would be 27 or 23.25. Would that matter then?
October 16, 200917 yr i dont know, i'm helpin so many people right now.. post the specs of the box again.
October 16, 200917 yr I just copied the OP.tunning will be at 35 hz.port area is 62 sqaure inchesbox volume is 4.29 ( havn't figured out what the 45's and braceing will displace)I just used 4 cubes for all my math.useing 3/4" mdf and will use double baffle.port opening will measure 15.5" W X 4" H , useing the bottom of the enclosure as the bottom of the port, ported to the side.port length will be 27.5" longthe port will fire toward a vertical mdf wall on the drivers side.sub will fire up, and i will plan on having it inverted, for now.it will work out that the sub will be almost centered in the vehicle.keeping in mind this is not a comp build so the pressure i would put on the mic is not factored in.the sub will be the furthest away from the internal port opening. 43.5" W X 17"D X 16"Hi think that is all the info needed, planning on useing the 1 5/8" coarse drywall screws, predrilling and countersinking all holes/useing wood glue and clamps, gotta look up prefered name brand of glue still.will either caulk with normal caulk
October 16, 200917 yr Author need carshow / sound off info asap, i got er' softened up.... cannot open pdf apps. currently..... gimme something i can google.chop
October 16, 200917 yr this is from somerset's website-Saturday, October 24th, 2PM:Cruise Entrance Gates Open in DowntownSomerset for the Show & Shine!!!It’s the Big Show!!! Blocks and blocks of showcars andtrucks! Stroll thru the downtown area admiring all thechrome and horsepower, talk to car owners and enjoy thefamily oriented atmosphere! Don't forget to visit our officialmerchandise trailer for the brand new '09 t-shirts for adultsand kids. In the Vendor Alley, you can sample great food,check out vendor displays and shop for new performanceand restoration parts. There is always plenty to see and doat SomernitesCruise! You will enjoy the great cruisin' tunes all over town too!This is from the PDF file-
October 16, 200917 yr here is the box u want to build- You sure u want to do that? I dont like boxes where the sub fires directly toward the port exit...That's one main reason why long, single shot ran ports are hard to cope with the box due to this.The port in the pick is 24.75" long internally displaced, 25.5" long total.Remaining space- 0.13cubes to equal your 4cubes NET. So, you got plenty of room left for bracing and 45s in the corners.
October 16, 200917 yr Author i mean you could right a book on what i don't know about box design..... can you throw something together a little better suited for us? i am going to spend all of tomorrow trying to make this come together and would like to start building this weekend...might grab a room at that Brecenridge Inn, that is usually where we crash at, how close is this to you?then just have a caravan down to the show....have you been there before? is there places where the women folk can get lost at for a while? she digs the shows, but not like all day ...lolwho all is meeting up with you?i will probably have the ol' lady, mikey & rattlebox317 (steve) tagging along.Chop
October 16, 200917 yr Author sent you a pm, gotta get off of here for tonight, will look it all over in the am.chop
October 16, 200917 yr i've never been down there but it doesnt matter, the WHOLE BLOCK is ours! They dedicated the whole downtown block to the show.
October 16, 200917 yr Author right on, just curious what all is going down..... been to some great shows and some real washes too.As long as I swing by the boat on the way down there, she should do fine. lol.can't believe they are calling for flurries this weekend here, couldn't be nice weather for me, now could it. loli think i am getting ready to go rip the seats out the truck in a few.....chop
October 18, 200917 yr Author used expanding foam to deaden back wall and started the floor for the box to rest on, also began to install side panels to dress out the rear of truck.
October 18, 200917 yr Author mr.shizzzon, have you had the time to finalize the new port design you had suggested?thanks chop
October 18, 200917 yr those arent glued yet are they?You suppose to be firing to driver side still, right?I'll get on it real soon.
October 18, 200917 yr Author those arent glued yet are they?You suppose to be firing to driver side still, right?I'll get on it real soon.No, there is no glue, yes port to the side stillthis area seen in the picture above is a platform , if you will, for the box to sit on....this seemed better than just throwing it in the rear on top of the seat.....54" side to side17" deepheight can vary, but the top of that rear board is 16" tallchop
October 18, 200917 yr ok, i got the port specs for your current box design-port is 15.5x3.75Internal Volume is 4.3cuft NETPort specs measuring from port opening on driver side-Port opening 15.5" deep x 3.75" highFrom opening inside, measure 3.75" back and build port wall 15.5" deep x 10" tall mounted on the floor.From that port wall, measure 3.75" back and build this port wall 15.5" deep x 6.25" high mounted underneath double baffle.You can add small 45 corners in this port run and keep it no longer than 2" in either direction.You will have 0.1 cuft left over for bracing. That should be enough.
October 18, 200917 yr Author okay, i got this one read, i see a vertical port that is on ther drivers side of the box...... so this will put the sub placement to the far paasenger side, if i am thinking correctly......which is fine by me on sub placement... so, looking for conformation of sub placement and will be throwing box together like tuesday....thanks for the reply on the laptop, that is Samantha's, (our oldest daughter), computer.....thankschop
October 19, 200917 yr Author will be making a attempt to grab the mdf tomorrow, if I do then the box should be able to get under way shortly there after.
October 19, 200917 yr Author easy buddy, just take some saw dust and begin to huff it slowly....breath deeply...... easy, just stay calm. you can get through this......where is your screw gun at? just hold it for a little while.....
