It is the amplifier's ability to control the cone movement of the speaker, such as starting and stopping. More technically it's the ratio between load impedance and source impedance of the amp. Really it isn't all that important and you probably couldn't tell a difference between any number. There's basically no difference above 50, and really not much even above 20.
Loudspeakers have a mind of their own. You send them a signal
and they add their own twist to it. They keep on vibrating after the
signal has stopped, due to inertia. That’s called “ringing” or “time
smearing.”
In other words, the speaker produces sound waves that are not part
of the original signal.
Suppose the incoming signal is a “tight” kick drum with a short
attack and decay in its signal envelope. When the kick-drum signal
stops, the speaker continues to vibrate. The cone bounces back and
forth in its suspension. So that nice, snappy kick drum turns into
a boomy throb.
Fortunately, a power amplifi er can exert control over the loudspeaker
and reduce ringing. Damping is the ability of a power
amplifi er to control loudspeaker motion. It’s measured in
Damping Factor, which is load impedance divided by amplifier
output impedance.
Let’s explain.
If the speaker impedance is 8 ohms, and the amplifi er output
impedance is 0.01 ohms, the damping factor is 800. That’s a
simplication. Since the speaker impedance and amplifi er output
impedance vary with frequency, so does the damping factor. Also,
the impedance of the speaker cable affects damping. Thick cables
(with low AWG) allow more damping than thin cables with (high
AWG).
The lower the amplifi er’s output impedance, the higher the damping
factor, and the tighter the sound is. A damping factor of 1000 or
greater is considered high. High damping factor equals tight bass.
How It Works
How does an amplifi er control speaker motion? When the loudspeaker
cone vibrates, it acts like a microphone, generating a signal
from its voice coil. This signal generated by the speaker is called
back EMF (back Electro Motive Force). It creates a current which
travels through the speaker cable back into the amplifi er output, then
returns to the speaker. Since back EMF is in opposite polarity with
the speaker’s motion, back EMF impedes or damps the speaker’s
ringing.
The smaller the amp’s output impedance, the greater is the effect
of back EMF on the speaker’s motion. An amplifi er with low output
impedance short-circuits the back EMF, so the back EMF drives the
loudspeaker with a relatively strong current that works against the
speaker’s motion. When the speaker cone moves out, the back EMF
pulls the speaker in, and vice versa.
In short, the loudspeaker damps itself through the amplifi er output
circuitry. The lower the impedance of that output circuitry, the more
the back EMF can control the speaker’s ringing.
To prove it to yourself, take a woofer that is not connected to
anything. Put your ear next to the cone and tap on it. You might
hear a low-pitched “bongggg” if the speaker itself is poorly damped.
Now short the speaker terminals and tap again. You should hear a
tighter thump.
Damping factor varies with frequency. As you might suspect, damping
factor is most important at low frequencies, say 10 Hz to 400
Hz.
Bottom Line......
Amps with a high effective Damping Factor
deliver clean, tight kick drum and bass.
here is an article from Richard Clark on Damping Factor
http://www.monstercable.com/mpc/stable/tech/A2412_Damping_Factor_Article.pdf
very nice explinations :werd_msword:
Take a moment to read this too: :)
