Posted October 21, 200916 yr I was just wondering which is best on the Fi Btl the dual one, or the dual two, an if order the universal what does it come set as or what? Please help me before i order thanks.
October 21, 200916 yr dual 1 and dual 2 depends on what amp you get. universal lets you change it from dual 2 to dual 1 later on if you want to and vice versa. Edited October 21, 200916 yr by iputon326
October 21, 200916 yr Author well i got a rockford T1500 amp wired down to 1ohm. so what would you perfer to get? Or is it hard to change out the universal, or what would you recommend ordering?
October 21, 200916 yr well i got a rockford T1500 amp wired down to 1ohm. so what would you perfer to get? Or is it hard to change out the universal, or what would you recommend ordering?get a dual 2 ohm sub that way you can wire it down to a 1 ohm load.
October 21, 200916 yr If I Remember Right, If You Get Dual 1ohm Then You Can Wire It Down To .5 OhmsAnd If You Get Dual 2 Ohm You Can Either Wire It To 1 Ohm Or 4 Ohms. Edited October 21, 200916 yr by Kent
October 21, 200916 yr I guess you didn't read FI's tech section. https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154ade69df862b0/shopdata/0070_Tech/0070_Speakers/0010_Tech.BTL/product_overview.shopscriptYou want the dual 2 with your amp.
October 21, 200916 yr Author I guess you didn't read FI's tech section. https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154ade69df862b0/shopdata/0070_Tech/0070_Speakers/0010_Tech.BTL/product_overview.shopscriptYou want the dual 2 with your amp.[/quoteTh.anks man but i did read it just didn't see anything about that sorry for asking for help thanks to the other guys though for all your help.
