Posted October 23, 200917 yr Well I just got back from picking up this earthquake amp. In a little rough shape but it is a ph1000w 2 channel. Any input on this?
October 23, 200917 yr Author wut sub did u say it was gonna b pushing?Arockford fosgate p3 dual voice 4 ohm
October 23, 200917 yr yea it will push it just fine. that amp rates at 250 rms per channel so just bridge it and u will b at ur 500 watts rms for ur sub. make sure u wire the sub 2 2 ohms
October 23, 200917 yr if it works i think u got a pretty good deal but it doesnt retail for 700 bucks...u can get it brand new for 270...but u payed 50 so u got a good deal.
October 23, 200917 yr Author if it works i think u got a pretty good deal but it doesnt retail for 700 bucks...u can get it brand new for 270...but u payed 50 so u got a good deal.Any way to check it?
October 23, 200917 yr check what? that it works? or that it will push the sub? if it turns on and pushes the sub at all it will definately push it, if it doesnt turn on then obviously it wont push it lol. hook it up and plug the sub in. make sure u set ur gain right and it will b fine.
October 23, 200917 yr if it works i think u got a pretty good deal but it doesnt retail for 700 bucks...u can get it brand new for 270...but u payed 50 so u got a good deal.Any way to check it?Only way to check it is by installing it, just make sure you can install in time before your warranty expires so you know it works.
October 23, 200917 yr yea it will push it just fine. that amp rates at 250 rms per channel so just bridge it and u will b at ur 500 watts rms for ur sub. make sure u wire the sub 2 2 ohmsWhy would he want to do that? The amplifier is only stable at 4 ohms bridged.You bought a mismatched amp for your sub. Your only option is to either wire the voice coils in series and bridge the amp at 8 ohms or wire one voice coil to each channel. Either way you'll only get about 350 watts out of the amp.
October 23, 200917 yr where does it say that it is only stable at 4 ohms bridged? if that is the case then wiring to 2 ohms bridged is def a bad idea...maybe the site i looked at was different that urs kl40.
October 23, 200917 yr Well on the two sites I found it just listed 4 ohm stereo power and 4 ohm bridged power. What site were you looking at? About 98% of 2 channel amps are only stable to 2 ohms stereo/4 ohms bridged.
October 23, 200917 yr Author I bought it it because it seemed like a deal. Just need something to get this up and going. I figured it would be better than that rf400-4. I dont have an extra couple hundred laying around...
