Posted October 23, 200915 yr I have a 94 civic trunk I need some ideas on a new box for highest spl. I have tried subs forward with 4 areo ports to the back, subs forward slot port to the back and sub forward slot port forward. I have about 33 deep by 35 wide and 15 high, im runnig 2 12 inch IA. LI's. Thanks for any help
October 23, 200915 yr I have a 94 civic trunk I need some ideas on a new box for highest spl. I have tried subs forward with 4 areo ports to the back, subs forward slot port to the back and sub forward slot port forward. I have about 33 deep by 35 wide and 15 high, im runnig 2 12 inch IA. LI's. Thanks for any helpWhen you had the subs forward and port forward was the front of the box sealed off so trunk and cabin were seperated (I think that should yield loudest spl in car. What all equipment is in the car, electrical upgrades, etc. Maybe time for more power depending on what you already have amplifier wise.
October 23, 200915 yr Author Yes I do need more power only outing 1200w to them butno wasn't seal off that's my next step and I'm going to try flaring the port
October 23, 200915 yr Yes I do need more power only outing 1200w to them butno wasn't seal off that's my next step and I'm going to try flaring the portWell then you got a plan, just make sure you seal off the box this time (there are plenty of builds with this done already if you need any tips or suggestions to go from). Good luck and share a build log with us once you start.
October 23, 200915 yr As Jay-cee has said make sure you seal off the enclosure. You may want to think about upgrading those Lethal Injections. Even though greatsubwoofers you may get better results with the Death Row or Death Penalty series with more power.Check out Thorshammer's build. He has gotten excellent results with his trunk setup.
