Posted October 24, 200916 yr has any 1 Sean a berth sheet from a zx1000.1 what was its top rms and @ how many volt's. And are they 1ohm stable Edited October 24, 200916 yr by danstow1
October 24, 200916 yr no they are not 1 ohm stable..i dont remember what volts it was but it was 1298 watts rms on my birthsheet.
October 24, 200916 yr Author no they are not 1 ohm stable..i dont remember what volts it was but it was 1298 watts rms on my birthsheet.really they are not 1 ohm stable that kinda sucks where you useing it to run an fi
October 24, 200916 yr no they are not 1 ohm stable..i dont remember what volts it was but it was 1298 watts rms on my birthsheet.really they are not 1 ohm stable that kinda sucks where you useing it to run an fiYeah a kicker zx1000.1 is 2 ohms stable (dont worry about what birth sheets say because if you try and run it at that power you will run into clipping (plus they just test one amp out of every 20 or 50 or so and write that number down as all amps birth sheet results). Actually it doesnt suck regardless the company brand your running with it because of its 2 ohm final load, what matters is the voice coil configuration that you have? I wouldnt buy a kicker amp either since they have set SubSonic Filters and you cant adjust them which will require you to tune your enclosure around the sub sonic filter instead of your liking.
October 24, 200916 yr Author no they are not 1 ohm stable..i dont remember what volts it was but it was 1298 watts rms on my birthsheet.really they are not 1 ohm stable that kinda sucks where you useing it to run an fiYeah a kicker zx1000.1 is 2 ohms stable (dont worry about what birth sheets say because if you try and run it at that power you will run into clipping (plus they just test one amp out of every 20 or 50 or so and write that number down as all amps birth sheet results). Actually it doesnt suck regardless the company brand your running with it because of its 2 ohm final load, what matters is the voice coil configuration that you have? I wouldnt buy a kicker amp either since they have set SubSonic Filters and you cant adjust them which will require you to tune your enclosure around the sub sonic filter instead of your liking.so jay Cee what would you sagest to run 2 L5 12's dual 2 ohm
October 25, 200916 yr Any amp within both subs rms range or more for headroom, it has to be 2 ohm stable with an adjustable sub sonic filter and underrated that fits inside your budget. What budget are you working with?
October 26, 200916 yr The zx 1000 or 1500 should be enough for these 2 subs, if you're set on Kicker.You just need an amp that can make 1000-1500 watts at 2 Ohms.If you don't have the sub yet, you can still make another choice.
