b-stock refers to slight damages on the case, the old and new heatsink is jsut the design differences. the new one will dissapate heat better and the best old one will dissapate heat almost as good. i tihnk on the sundwon section of this forum jacob say exactly the difference of each!
  • Replies 58
  • Views 7.5k
Ive been lookin at the same one. It an awesome price!
It means it has older version parts in it.
Ok thanks! so B-stock is fine it just might be scratched or something? in that case i dont care because i'm not buying an amp for looks haha.
And old heatsink will also be alright?
And will i have any problems if it's refurbished?
Thanks
I ran into one problem with my 3000D and the RCA mosfits but Chris at Db-r will take care of ya
you get a one year coverage
you will have no problems if it is referb by db-r i think he comes with a nice warrenty on all his work!
By the way, how much is the budget for the entire install? Just wondering cause it seems like you are doing pretty good in the paper dept at 15! I had no dollas.
I think i'm going with a SAZ 3000D from db-r.
But i also have questions about wiring and the box.
First off, what type of wiring should i get?
And i want my box ported but don't know how to make one or the dimensions or anything since this is my first system, where could i find specefic instructions on a box for a Fi BTL 18" or where could i buy one?
Also will Best Buy be able to install everything, the sub, amp, and battery.
Thanks
o boy!! lol! a first timeer!!!!
o and don't let ANY ONE install it other then you!! you do it so it is done right!
as for box building you wnat to go ported which is good!! now you need to look on Fi site for box recommendations!!
Trying to keep it under 3 grand haha i'm sure it will be, what i've calculated so far is this:
Fi BTL 18" $500
Powermaster 3100D $350
SAZ 3000D around $600
H/O altenator $250-ish?
which comes out to 1700 so i have plenty left for wires and the box and instalation
then you need to tell us where the sub box is going to go! liek max and min dimensions of your trunk!
CrazyKenKid i will mess it up if i installed it myself i know nothing about wiring or how to do it.
The best buy by my house is very good with all this stuff and if they mess it up, they pay for it in full.
ALSO! A question to everyone:
Dual 1 OHM or Dual 2 OHM?
You can go anything but ported with the BTL.
Definitely do it yourself. Better learn quick to do it right.
5-10 cuft and 32-35hz for daily
x2 also your going to need at least 40 feet of 1/0 gauge
big 3 should also be done to
and get a duel 2ohm! so you can wire it down to 1ohm load nominal!
And it will go in the trunk of a Ford Explorer most likely a 2004?
So not like huge but not small either, i'm not sure on exact dimensions
also don't thin you will mess it up! you learn from experience lol!!!
You will need more than 1 batt for the 3000D.
ok then 2 Powermaster D3100
well 2 d3100 will be safer but you are getting a H/O lol! but 2 to be safe would be nice!! and if you got the extra cash go for it!
If I said no again would you go to 3? You should research this a little more. It can get pricey.
Well i said before, im starting with 1 D3100. then go to 2 if needed.
