Use 50 Hz.
May I please know whats the difference?
Technically, 10 Hz :)
If you used 60 Hz. you would end up setting the gain too high.
Haha, I think the technical part is pretty easy to get at first sight :P
Ok then, will look for that user with the free sines again and download his rar package to get the 50Hz.
  • Replies 175
  • Views 16.3k
  • ralstonballa2413
    ralstonballa2413
    I have owned that hifonics amp your looking at and it is a very good budget amp but I had a few problems with it in the few months I owned it. I switched to sundown and have had no problems with the
  • jcarter1885
    jcarter1885
    The O-scope is the best way to set your gain but also the most expensive way to set your gain also, since it cost an arm and a leg more than a DMM.
  • alternator- the bigger the better, IMO ohio generator builds the best out there, and if you give them a call they will be more than willing to help you out on designing and building an alternator to s
