Posted November 5, 200915 yr Im in need of a new home theater reciever for my room. My older sony reciever finally gave out the other day, and i cant stand listening to my games and movies through my tv speakers! I dont have too much money to spend on one(roughly $200). I found a couple Harman Kardon HK AVR 247's on ebay that were going for a good price, and i was wondering if that reciever will suit my setup. If not, could someone point me in the right direction? I have Polk monitor 50 floorstanders, polk r15 rears, and a Polk CS1 center. Its manly 50% games, 25% music, and 25% movies. thanks Edited November 5, 200915 yr by mwerling1212
November 5, 200915 yr Author Anyone have input on this reciever? I need to get one before call of duty mw2 comes out!
November 5, 200915 yr Admin I have not used that unit, but I have not heard any negative reviews on HK receivers. Are there any certain features other then a 5.1?
November 6, 200915 yr Author here are the features:EzSet/EQ™ automated setup (microphone supplied)Graphic on-screen display with HDMI, component, composite and S-videoTwo-line dot-matrix front-panel displayColor-coded connectionsProgrammable 11-device main remote controlSource input renamingA/V Sync DelayRS-232 serial port for system upgradesSwitched accessory power outletRemote infrared (IR) input and outputMultiroom IR inputThe AVR 247 is Simplay HD-verified for compatibility via the HDMI connection with other Simplay HD-verified products.Audio Section50 Watts x 7, seven channels driven at full power at 8 ohms, 20Hz – 20kHz, <0.07% THD (surround modes), 350 watts total65 Watts x 2, two channels driven at full power at 8 ohms, 20Hz – 20kHz, <0.07% THD (surround off mode), 130 watts totalHigh-current capability, ultrawide-bandwidth amplifier design with low negative feedbackAll-discrete amplifier circuitryDual independent power supplies, for front and surround channelsQuadruple-crossover bass management24-Bit, twin-core Cirrus Logic® CS 49510 DSP processor with 32-bit postprocessor192kHz/24-bit D/A conversionSampling upconversion to 96kHzSurround ModesDolby® Digital EXDolby Pro Logic® II and IIx (Movie, Music and Game)Dolby Virtual Speaker version 2 (Reference two- or three-speaker; wide two-, three-, four- or five-speaker)Dolby Headphone Version 2DTS® (5.1; DTS stereo; DTS-ES® 6.1 discrete and matrix)DTS 96/24™ (DTS stereo)DTS Neo:6® (Cinema 3-, 5- or 6-channel; music 5- or 6-channel)Logic 7® (cinema, music and enhance – 5.1 and 7.1)Hall 1 and Hall 2 (5- or 6-channel)Theater (5- or 6-channel)5- or 7-Channel stereoSurround Off (DSP or analog bypass)Audio InputsAM/FM/XM®* tunerCDTape6-/8-Channel direct/DMP for iPod** connectivity with audio/video playback Audio/Video Inputs (With S-Video)4 composite video, video 4 (on front panel)DVDThree assignable 100MHz component video inputsSimplay HD™-verified HDMI™ 1 and 2 (with audio/video processing and 1080p pass-through)DCDi® by Faroudja video processingTranscodes composite and S-video to component videoTranscodes 480i video to HDMI format, with upscaling up to 720pUpgraded graphic text-based on-screen displaysDigital Audio InputsCoaxial: two rear-panel/one front-panelOptical: two rear-panel/one front-panelOutputs7.1-Channel preamp outputsTape (analog audio)Video 1 (analog audio and video)Video monitor (composite, S-video and component)Digital audio (one coaxial, one optical
November 6, 200915 yr Hk has always been good quality stuff. I'd go with it, especially for that price.
