Posted November 7, 200916 yr Okay, I have a guy that lives behind me that has three 12" Kicker CVR's . He currently has them in a very crappy box and is wanting me to throw a better box together for him.I stand to make a few bucks from this project. that is all. there is no possibility of him competing or even keeping this setup long term. just a better box than he has and some cash in ol' chop's pocket.So for the sake of getting good responses, i am not looking to buy these, i only want to get some good input on what volume and tunning would be good for them to get loud with. not a fart box, but i am sure he has no interest in catching the lows.I have not used these subs before..... off the top of my head i would think 2 cubes per and tune to 36 hz. ..........is this good enough for these subs? i wish i could tell you what power he will have running to them but i really don't think he will know either, lol. so i will assume the rated power will be supplied for this build. also .... the specs say they can either be 2 or 4 ohm vc's........... without a dmm, is there any way of telling on these subs what the impedance is? like visually i am saying. if not i will try to get mikeys.so ..... volume and tunning for three 12" cvr's in the trunk of a mid 90's caprice..... port and subs friring to the rear..... slot port......... any suggestions?thanks in advance for the help....Chop
November 7, 200916 yr Probably about 6.75 ft3 after all displacements at 36hz would be good chop.Check that. If he has no interest in the lows and just wants it loud then about 40-45hz.Ive always like the slot port. Both rear firing sounds like a good place to start.The D2's will wire to 1.34ohms and the D4's will be 2.67ohms. Hopefully his amp is 1 ohm stable.Btw thanks for the pics dude. Got any more? Edited November 7, 200916 yr by bigrank916
November 7, 200916 yr Author Probably about 6.75 ft3 after all displacements at 36hz would be good chop.Check that. If he has no interest in the lows and just wants it loud then about 40-45hz.Ive always like the slot port. Both rear firing sounds like a good place to start.The D2's will wire to 1.34ohms and the D4's will be 2.67ohms. Hopefully his amp is 1 ohm stable.Btw thanks for the pics dude. Got any more?thanks man......i imagine if i point toward getting something 1 ohm, he will get something along that line......perhaps 38 hz. will do then..... not sure what these subs will do....i have been spreading it a little too thin around here.... i will attempt to get some more pics soon..... i sent a pm requesting your mailing address.... did you not get that or read it yet????? might get some mail !!!!Thanks for the helpchop
November 7, 200916 yr Probably about 6.75 ft3 after all displacements at 36hz would be good chop.Check that. If he has no interest in the lows and just wants it loud then about 40-45hz.Ive always like the slot port. Both rear firing sounds like a good place to start.The D2's will wire to 1.34ohms and the D4's will be 2.67ohms. Hopefully his amp is 1 ohm stable.Btw thanks for the pics dude. Got any more?Actually the D4's can be wired to 1.33334 ohms, I dont know how I just know they can. My friend has 3-12" CVRs tuned to 30 Hz and bangs but he has some funky wiring, me and the local car audio shop were suprised because we didnt think he was wired that low and sure damn was.
November 7, 200916 yr Probably about 6.75 ft3 after all displacements at 36hz would be good chop.Check that. If he has no interest in the lows and just wants it loud then about 40-45hz.Ive always like the slot port. Both rear firing sounds like a good place to start.The D2's will wire to 1.34ohms and the D4's will be 2.67ohms. Hopefully his amp is 1 ohm stable.Btw thanks for the pics dude. Got any more?Actually the D4's can be wired to 1.33334 ohms, I dont know how I just know they can. My friend has 3-12" CVRs tuned to 30 Hz and bangs but he has some funky wiring, me and the local car audio shop were suprised because we didnt think he was wired that low and sure damn was.Id love to see how but are you sure they werent svc? I never heard that before but there is a first time for everything.
November 7, 200916 yr Probably about 6.75 ft3 after all displacements at 36hz would be good chop.Check that. If he has no interest in the lows and just wants it loud then about 40-45hz.Ive always like the slot port. Both rear firing sounds like a good place to start.The D2's will wire to 1.34ohms and the D4's will be 2.67ohms. Hopefully his amp is 1 ohm stable.Btw thanks for the pics dude. Got any more?Actually the D4's can be wired to 1.33334 ohms, I dont know how I just know they can. My friend has 3-12" CVRs tuned to 30 Hz and bangs but he has some funky wiring, me and the local car audio shop were suprised because we didnt think he was wired that low and sure damn was.Id love to see how but are you sure they werent svc? I never heard that before but there is a first time for everything.Yeah Im pretty sure beause when I was ordering my D2 ohm CVX's and we were talking about how mine can be wired to 1.3333 ohms and his cant since his cvr's where D4 but he should me and it is some crazy wiring that I cant even remember off the top of my head (its rather confusing but it drops him down to close to a 1 ohm load.
November 7, 200916 yr Author i think he currently has a 2 ohm stable amp.... does the cvr's have any markings that would note the impedance?i have not played with the odd numbers when it comes to ohms.... would these numbers do okay on the corrasponding amps?like 1.34 ohms.... is that okay for a 1 ohm stable amp..... is there any information to be noted?same question toward the 2 ohm rating also..... thanks for the input,chopi will check pm in a sec.
November 7, 200916 yr As long as the load of the speakers is less than the amp load then your cool, 1.3333 will work fine for 1 ohm stable amp (I wouldnt try it on a 2 ohm stable amp). 2.67 speaker load will do fine on a 2 ohm stable amp.www.the12volt.com will help you in multiple subwoofer wiring, and yeah they should have markings on them (my CVX's do). If not then just get a dmm, that will get it for you if the subs dont have markings.
November 7, 200916 yr Author As long as the load of the speakers is less than the amp load then your cool, 1.3333 will work fine for 1 ohm stable amp (I wouldnt try it on a 2 ohm stable amp). 2.67 speaker load will do fine on a 2 ohm stable amp.www.the12volt.com will help you in multiple subwoofer wiring, and yeah they should have markings on them (my CVX's do). If not then just get a dmm, that will get it for you if the subs dont have markings. thanks bro... waiting for him to get back so i can snatch the subs out , lol.chop
November 16, 200916 yr i have tried kicker factory rec specs & its 1 of those few main stream companies that actually work good so go to their website & see what they have
