Posted November 7, 200915 yr so i didnt know where to put this, but feel free to move iti am doing an overhall on my car and setting up a friends so i figured i would do it right the first timei have installed a few systems, but never but a second battery in a carso im putting the same system in my car and a friends which consists of a 3000W fusion amp, FI BL12 fully loaded subs (dual 2 ohm) and an extra batterythe cars are an 03 525i and 2008 Wranglerso i figured 1/0 wire to connect the new battery and 4 gauge from the battery to ampdo i need a fuse between the car battery and audio battery and audio to amp or just on the power wire to the amp, and how big of a fuse (the amp has 4x40amp fuses)and then i was thinking 12 gauge from the amp to subalso do i need a battery isolator and if so which oneso this is the plan:12 ga from amp to sub4 gauge with fuse from 1400W battery with some type of isolator1/0 ga from car battery to audio batterysound good?Patrick
November 7, 200915 yr so im putting the same system in my car and a friends which consists of a 3000W fusion amp, FI BL12 fully loaded subs (dual 2 ohm) and an extra batterythe cars are an 03 525i and 2008 Wranglerso i figured 1/0 wire to connect the new battery and 4 gauge from the battery to ampdo i need a fuse between the car battery and audio battery and audio to amp or just on the power wire to the amp, and how big of a fuse (the amp has 4x40amp fuses)and then i was thinking 12 gauge from the amp to subalso do i need a battery isolator and if so which oneso this is the plan:12 ga from amp to sub4 gauge with fuse from 1400W battery with some type of isolator1/0 ga from car battery to audio batterysound good?PatrickOk couple of things:that fusion amp WILL NOT give you 3000 watts not even on its best of days. if it has 4x40 amp fuses. that 160amps. to figure out wattage out OHMS LAW-- voltage x amperage.let's figure a good voltage of 14.5 -- 14.5 x 160 amps= 2320 watts total. seeing how your probably won't get 14.5 volts constant. it wll be even lower.the run from the front battery to the back battery should be fused twice, one as close to the front battery and the second as close to the back battery as you can.second if you can get zero gauge into the amp.DO IT!Third. You have to do the big three in all zero gauge if possibleFourth. NO ISOLATOR!. in my experience they add resistance and they are not needed unless you plan on bumping while the car is off and you want to spare your starter battery and i wouldn't suggest that. Edited November 7, 200915 yr by djphilly
November 7, 200915 yr so i didnt know where to put this, but feel free to move iti am doing an overhall on my car and setting up a friends so i figured i would do it right the first timei have installed a few systems, but never but a second battery in a carso im putting the same system in my car and a friends which consists of a 3000W fusion amp, FI BL12 fully loaded subs (dual 2 ohm) and an extra batterythe cars are an 03 525i and 2008 Wranglerso i figured 1/0 wire to connect the new battery and 4 gauge from the battery to ampdo i need a fuse between the car battery and audio battery and audio to amp or just on the power wire to the amp, and how big of a fuse (the amp has 4x40amp fuses)and then i was thinking 12 gauge from the amp to subalso do i need a battery isolator and if so which oneso this is the plan:12 ga from amp to sub4 gauge with fuse from 1400W battery with some type of isolator1/0 ga from car battery to audio batterysound good?PatrickHow about reading the thread names, we have a section that says Amplifiers, Head-Units, Electrical (it would go in the electrical section). Everytime you post you type "I dont know where this goes, nobody does that". Just read each sections title and description about it under the title and post in appropriate section, its not taht hard man, at all just takes some reading and common sense.I dont see the amp being that powerful, when you look at its specs it is only rated at 1500rms x 1 @ 1 ohm (the 3000w rating is max). But that amp will push that BL very well.Battery #1--- fuse ---------------------------------------- fuse ----- Battery #2 (1/0 AWG wire)Battery #2--- fuse -----------------------------------------------------Amp (1/0 AWG wire)No Isolator unless you play with your car off alot, if not then it is not needed.
November 7, 200915 yr Author so im putting the same system in my car and a friends which consists of a 3000W fusion amp, FI BL12 fully loaded subs (dual 2 ohm) and an extra batterythe cars are an 03 525i and 2008 Wranglerso i figured 1/0 wire to connect the new battery and 4 gauge from the battery to ampdo i need a fuse between the car battery and audio battery and audio to amp or just on the power wire to the amp, and how big of a fuse (the amp has 4x40amp fuses)and then i was thinking 12 gauge from the amp to subalso do i need a battery isolator and if so which oneso this is the plan:12 ga from amp to sub4 gauge with fuse from 1400W battery with some type of isolator1/0 ga from car battery to audio batterysound good?PatrickOk couple of things:that fusion amp WILL NOT give you 3000 watts not even on its best of days. if it has 4x40 amp fuses. that 160amps. to figure out wattage out OHMS LAW-- voltage x amperage.let's figure a good voltage of 14.5 -- 14.5 x 160 amps= 2320 watts total. seeing how your probably won't get 14.5 volts constant. it wll be even lower.the run from the front battery to the back battery should be fused twice, one as close to the front battery and the second as close to the back battery as you can.second if you can get zero gauge into the amp.DO IT!Third. You have to do the big three in all zero gauge if possibleFourth. NO ISOLATOR!. in my experience they add resistance and they are not needed unless you plan on bumping while the car is off and you want to spare your starter battery and i wouldn't suggest that.ok thanksi know it wont run 3000W, i just said that so people know which one i am talking abouti am working on the big three nowthe amp will barely hold 4 gauge wire, so do i need to run 1/0 to an adapter?
November 7, 200915 yr You can buy an adaptor but if you already have the 4 guage than it will be fine, most will tell you to up it to 1/0 awg but it isnt really worth it.I would just do it like this:Battery #2 to fuse block 1/0 awg wire and the wire leaving fuse block going to amp use 4 gauge and you will be cool.
November 7, 200915 yr ok thanks, now time to go shopping!!Buy me some 1/0 awg while your out, appreciate it.
November 9, 200915 yr so im putting the same system in my car and a friends which consists of a 3000W fusion amp, FI BL12 fully loaded subs (dual 2 ohm) and an extra batterythe cars are an 03 525i and 2008 Wranglerso i figured 1/0 wire to connect the new battery and 4 gauge from the battery to ampdo i need a fuse between the car battery and audio battery and audio to amp or just on the power wire to the amp, and how big of a fuse (the amp has 4x40amp fuses)and then i was thinking 12 gauge from the amp to subalso do i need a battery isolator and if so which oneso this is the plan:12 ga from amp to sub4 gauge with fuse from 1400W battery with some type of isolator1/0 ga from car battery to audio batterysound good?PatrickOk couple of things:that fusion amp WILL NOT give you 3000 watts not even on its best of days. if it has 4x40 amp fuses. that 160amps. to figure out wattage out OHMS LAW-- voltage x amperage.let's figure a good voltage of 14.5 -- 14.5 x 160 amps= 2320 watts total. seeing how your probably won't get 14.5 volts constant. it wll be even lower.the run from the front battery to the back battery should be fused twice, one as close to the front battery and the second as close to the back battery as you can.second if you can get zero gauge into the amp.DO IT!Third. You have to do the big three in all zero gauge if possibleFourth. NO ISOLATOR!. in my experience they add resistance and they are not needed unless you plan on bumping while the car is off and you want to spare your starter battery and i wouldn't suggest that.ok thanksi know it wont run 3000W, i just said that so people know which one i am talking abouti am working on the big three nowthe amp will barely hold 4 gauge wire, so do i need to run 1/0 to an adapter?Get a reducer
