Posted November 15, 200916 yr Box is going in a Tahoe.Fi BL 155.0cuft NET @32hz using 108.5sqin of port.Awaiting Hunterp223's approval.
November 16, 200915 yr i like it..... everything firing to the rear , will look good with the hatch open. would be cool to build.
November 16, 200915 yr Author actually, that's not how it's designed, it's designed to have sub up, port back.The reason why the rear is double baffled is because it isn't braced and the top doesn't need to be.If you like it, refer to your pms.
November 16, 200915 yr actually, that's not how it's designed, it's designed to have sub up, port back.The reason why the rear is double baffled is because it isn't braced and the top doesn't need to be.If you like it, refer to your pms.oh, I see....... well i still like it, lol.
