Posted November 27, 200916 yr I am starting my first wall build and need a little bit of guidence. The truck is a 1986 GMC S15 ext cab (2wd) The equpiment I'm using is 15" Alpine Type R The amp I'm getting is a two AQ 2200dI'm going to have the drivers wired to 1 ohm. What I really need help with is the building part of the project. I've never seen a wall in person or built one. I seen pictures online and have the grasp of it. So.. if a box builder could help me with the blueprints on my project I can get started.The kinda wall I want is a competition wall, so I was told..It seems to be a sheet of wood from floor to celing with the port on the driver side.
November 28, 200916 yr I am starting my first wall build and need a little bit of guidence. The truck is a 1986 GMC S15 ext cab (2wd) The equpiment I'm using is 15" Alpine Type R The amp I'm getting is a two AQ 2200dI'm going to have the drivers wired to 1 ohm. What I really need help with is the building part of the project. I've never seen a wall in person or built one. I seen pictures online and have the grasp of it. So.. if a box builder could help me with the blueprints on my project I can get started.The kinda wall I want is a competition wall, so I was told..It seems to be a sheet of wood from floor to celing with the port on the driver side.Try and send a pm to shizzzon (member here), he should be able to help you.
