Posted November 28, 200916 yr What is the best and easiest way to get get 16v to your amps in a daily driver? Do you need a seperate regulator for your alternator? What about the MLA Module, anyone ever used it and how well does it work?
November 28, 200916 yr First, why do you want to run 16V daily?It can be useful in a comp vehicle. Completely unnecessary for daily use.
November 28, 200916 yr the easiest way i know of would be to install the XS VCM and replace all batteries in the car with XS 14v AGMs.It is kinda expensive but to maintain 16v daily.. it isn't cheap.Daily means sustained use and 16v sustained use is around the max in car electronics can handle.
November 28, 200916 yr and 16v sustained use is around the max in car electronics can handle.I would highly recommend against sending 16V to your vehicles electronics.
November 28, 200916 yr well then, i hope the rest of CACO realizes this because when the VCM gets released next week... this is their impressional use.
December 1, 200916 yr Author So technically the safest way to do so would be with a second alternator dedicated to your subwoofer amps and using the VCM, and using your primary alternator for your mid/highs?
December 2, 200916 yr Admin well then, i hope the rest of **** realizes this because when the VCM gets released next week... this is their impressional use.
December 2, 200916 yr So technically the safest way to do so would be with a second alternator dedicated to your subwoofer amps and using the VCM, and using your primary alternator for your mid/highs?Again, why do you want to run 16V daily?
December 2, 200916 yr well then, i hope the rest of **** realizes this because when the VCM gets released next week... this is their impressional use.I don't think that's their impressional use at all. I think of it as an adjustable MLA, versus having set points like an MLA does.If people are dumb enough to turn it up to 17 volts then they deserve to blow up their ECM.
December 2, 200916 yr Take a look at this ... http://store.hlabs.com/pk4/store.pl?view_product=38 match that with the ... XS Power D1600 and you have your "daily" setup while maintaining your factory electrical.Jacob from Sundown Audio runs(ran) this similar setup in his Jeep.
